SOLD Parts The parts in here have already been sold. The topics will be kept for a few months for reference. |
400 Pistons/Rods Ross/Childs&Albert new f/s
New pistons/rods for a Pontiac 400. 4.15 Ross forged pistons. Flat tops, 8cc valve reliefs. Bought from KRE. Childs&Albert forged rods. Rods are press fit. Rods are quite old but appear to be unused and gorgeous. My machine shop installed the wrist pins and used them for mock-up to measure deck height. My crank turned out to be junk, now I'm going with a 433. Would love to use the rods but don't want to press off the pistons. Comes in original box, with all Ross docs, bob weights specs for balancing and torque specs for rods.
$1000 plus shipping. Located in Western WA
67 LeMans, 326, M20, 3.31 12 Bolt |
Bump, $1000 shipped
Do they come with rings? What are the ring groove widths?
1969 carousel red firebird 455, richmond 5 speed 1964 540 gto 1971 lemans sport convertible 1972 Maverick under slow construction |
Ring groves are 1/16 1/16 3/16. I fit the top rings to my block, so I wasn’t gonna include em. Planning on buying another set of Ross pistons and using those rings for a 4” stroker build
Did you slide them in your block what was the piston to deck Height ? Was your block decked? Do you have the piston spec sheet
I didn’t measure myself, but my machine shop did. I had my block zero decked, didn’t ask how much they cut. They do come with a spec sheet and bob weights from when I had my crank balanced. Using the spec sheet I calculated a 10.22” deck height.
An you post it the sheet please
Bump
The Following User Says Thank You to Joe-Touring For This Useful Post: | ||
Bump, also decided to include the rings. Top rings have been fitted, should be able to buy a top only set from Total Seal. The bag has the part number on it
Ttt
$900 shipped
$800 Shipped
Stock Pontiac on big end of rod for a stock crank?
That’s right
Pending
Sold, thanks PY
