Has Anyone Seen this Defect in a Forged 4.50” stroke Crankshaft? Pics inside
So this is a new one for me and puts a Damper on my build for a little bit, there is a void in the Chamfer of #6 rod journal and it goes into the oil passage!!! WTH? I thought being forged this would not or really could not happen?
If I hadn’t somehow seen this and just thought it was odd before I started inspecting it real close and realizing it was an actual hole this could’ve easily blown at my engine I got real lucky!!!
Build it Right Build it Once!!! Just another Engine Builder from the Northwest lol |
Just curious does the drilling make it to the main? Whos crank.
It does go through like it should, there is a void between the internal passage and the Chamfer
Did you get this crank from eBay? It is probably a factory blem crank that the vendor passed on to you as a normal part.
Have you contacted the seller about it? My guess is that this crank garbage and probably not worth putting money into repairing. You would probably be better off getting another one. |
That breakthrough is rather frightening in the fillet area. So one of several things may have caused this. 1. Incorrect set-up for drilling. (unlikely IMO). 2. Drilling with a dull drill bit, (possible) 3. Hitting some crap or inclusion while drilling sending the bit off track (possible). 4. Improper index when drilling was started (possible). IMO, that crankshaft is a throw away. Only real way to know where the various drillings are placed would be to X-ray the crank. How many other drillings are .010" or .005" away from breaking through elsewhere in the crankshaft? Great catch on your part! I would be concerned using anything from this vendor. For Chinese forgings, my choice would be Molnar, Scat, Eagle in that order.
Wow . I've never seen that ..
My Half AN Injun..... |
If that’s a cast crank then don’t even think about using it!
If it’s forged you could get it welded and recut, but I would still have a big concern that the oil passage was misdrilled enough to not intersect as it should with the other one. It looks like it could be up to 1/8” off from where it should be!
I do stuff for reasons. |
So much for quality control .
That's not your fault. You shouldn't have to pay anything... I hope it works out for you Good luck...
[QUOTE=charlie66;6325189]So much for quality control .
That's not your fault. You shouldn't have to pay anything... I hope it works out for you Good luck...[/QUOTE Yeah no kidding!!! I don’t have a lot of time though so I think what I’m gonna do is do like they said and just keep this Crankshaft find somebody who knows what they’re really doing and see if it can be repaired if they can grind it out weld it back up and then re-grind it I don’t know and then get the new crank so I guess that’s some consolation but still I would’ve just bought a nicer Crankshaft if I had all this extra money to spend on shipping
[QUOTE=Pontiac Derek;6325213]
2007 Norwalk Quick 16 Winner 8.960 @152.24 8.96 dial http://www.youtube.com/watch?v=8HY_nJR9Aa0&NR=1 |
[QUOTE=Jim Zeek;6325216]It’s an SGI crankshaft from EBay, they are sending me another one, even though this is an all iron low rpm deal if I didn’t catch that it for sure would have eventually smoked the bearings or broke, I will be having the next one thoroughly checked out!
[QUOTE=Pontiac Derek;6325350]Why not support our Pontiac Vendors? This probably would not have happened.
Dave Polichena |
Wow I was just about to buy a rotating assembly w a forged crank and now I’m. Completely second guessing it over my factory Pontiac stuff that thing is a POS and I’d never pay them the $128 I’d charge them for my wait time. I’d keep it to make a lamp or something but it would NEVER go in one. Of my engines . That’s crazy, too much to lose Just my .02
Happiness is just a turbocharger away! 960 HP @ 11 psi, 9.70 at 146. Iron heads, iron stock 2 bolt block , stock crank, 9 years haven't even changed a spark plug! selling turbos and turbo related parts since 2005! |
