Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
FS : 67 Firebird subframe
I recently purchased an aftermarket frame. I would like to recover some of the cost by selling my stock frame and suspension
Comes with: Upper and lower control arms Springs from a 6cyl firebird, monroe shocks Spindles Master cylinder, prop valve disc/drum. Brake rotors, calipers, pads, dust Shields, caliper brackets. Converted 4 piston to single piston brakes. Steering components including pump, gearbox, lines, I started sand blasting the frame and control arms, but it needs a little more to finish up. It needs new mounting plates welded in. And there are some cracks that need to be welded. I am hoping to get $750. Pictures will be up soon. Thanks for looking, Ozzy.
463 Stroker Kit. ross pistons. h beam rods. eagle crank. 62 heads 72cc, port matched Performer RPM-850DP Auburn- 3.55 gear CC HR custom grind |
