Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here. |
Solid Roller Camshaft What do you have?
What do you have for a solid roller in high 269 to 279 area preferably 110 LSA
.440+ to .455 lobes 50mm stock block. Last edited by harry k; 12-04-2023 at 12:44 PM. |
meant 48mm stock block
also can use duration @50 259+ |
I have Marty Palbykins "Back-up" 400 Pontiac Camshaft (when he ran 6.96 and 206 mph in the quarter.
Timing is not good thought as I am moving and the camshaft is in a safe spot in my new barn. The question is where in the barn is the camshaft. It might also be more duration than you are requesting. Sorry Harry. It fit a heavily modified 1967 stock Pontiac (2 bolt main block converted to splayed main caps). Tom V.
I have a Cam Motion solid roller that's 269/272 with 108 sep. Cam card below. But it's only got .370/.381 lobe lift.
I have an Ultradyne 280/290@0.050" with 0.426" lobes and a 108 LSA. I have to verify the lobe specs.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
TTT
Std. Journal Pontiac Roller
I have a 272/280 110 LSA with lobe lifts of .480 and .487 respectively.
PM sent.
Bump as well.
I have comp 272 / 278 @ .050 on a 108. Has .420 lobes
