I found a couple of these on the front driver's floor of my car. Does anyone know what it is? It's about 1 1/2" long.
Maybe this?
So long, farewell. |
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post: | ||
Amazing! Mike, what don't you know about our cars?
![]() He also posted about a loose shifter. I was able to put two and two together. Hard part was searching for a picture...
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
Okay... So it's a spacer for that thin bolt that goes sideways on the shifter? I was thinking the loose, sloppy shifter question and this piece might be related but wasn't sure.
I guess my usual McGanzer Flange comment would be pointless now.
The Following User Says Thank You to dataway For This Useful Post: | ||
It's more of a positioner. It keeps things from floating around.
Got it. Thanks so much!
I believe it's called a pivot bolt bridge plate.
Are you SURE it's not called a Pivot Bolt McGanzer Plate ?
At this point in my life, I’m not sure of anything.
The Following User Says Thank You to tempest1964 For This Useful Post: | ||
Don't worry, you're right. It's a bridge plate. Dataway was just trying to use his standby reply to these type of questions.
Originally I thought it might be a muffler bearing support bracket
Tim Corcoran |
The Following User Says Thank You to Tim Corcoran For This Useful Post: | ||
Nah. Those have grease fittings.
The Following User Says Thank You to Bill Hanlon For This Useful Post: | ||
Only on the older ones, the removed those on the lubed for life models.
The Following User Says Thank You to jerry455 For This Useful Post: | ||
