Front drum brakes
Does anyone know where I could purchase new front brake drums for my 1970 GTO?
I do not want Chinese parts |
HELLO ??!?!?!?
a lot of people yank the original front drums and swap to disc, so check parts for sale here or post a wanted ad. you could also check Rock Auto.
http://gloryrestoparts.20megsfree.com/ 1970.5 Pontiac Tempest GT-37 400ci 4bbl 4sp 3.90:1 12.73 @ 112.42 2011 Pure Stock Drags 12.71 @ 110.58 2013 Martin FAST/FS race 12.70 @ 111.74 2014 Pure Stock Drags 12.60 @ 111.66 2015 Martin FAST/FS race 1968 Pontiac Firebird 400 TH400/3.08 open export car - factory heater delete 14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags 14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race |
Inline Tube should also have these. Scott
Please check out my YouTube channel for vintage/classic car and truck builds and shenanigans! https://www.youtube.com/watch?v=jq61KxKp1Is&t=14s |
If you're not in a hurry, I will be pulling mine off to install discs probably by the end of summer. You can have them for the cost shipping if you want.
Mitch Kunath |
If you have the extra money laying around then i would suggest buying a power disc kit from jegs, summit or ground up.... it makes all the difference in the world.
-Andrew
1969 el Camino SS 396 1970 LeMans Sport 350 2000 Camaro 3.8 |
Thanks so much everyone for your ideas and advice!!
I decided to install a disk brake kit instead of replacing front drums!! I installed kit 2 weeks ago and do like it. Only wondering if anyone else installed one of these kits with vacuum booster and master cylinder, spindles, calipers, hub, back plate etc...all at the same time? What I noticed is the travel on the brake petal goes further down before any braking. Petal is firm, but have not slammed on brakes yet to check for sudden stops, wanted to brake in first. Is there anything to check? |
i installed the kit in my el camino and it was funky at first but i changed the lines and bled them, it worked like a champ.
Also check the rear shoes to make sure they're properly adjusted . . .
Regards, "455HO" Lloyd 2008 GMC Sierra Denali 2WD Crew, L92 6L80E, Silver w/ Ebony guts, 14.26 @ 98 |
Also look at the rear brake hose, many times they look fine from the outside and they fracture inside and swell upon application causing low pedal. |
