Engine date versus Body build date
Hey guys I'd like to hear your thoughts on something. My 65 GTO was built in the second week of May in Fremont. I have a chance to pick up an engine that is cast the second week of March. Is this two month spread too early or would it be considered typical for a factory date range? Just curious if I should try and get it or if I should keep looking for something cast in April...
Thanks |
My 4th week of November built car has a October 21st cast block. So about 4 weeks from casting in Michigan to installation at the KC plant. Used to own a 1st week May Pontiac assembled car that had last week April/1st week May castings. Don’t think these blocks sat around gathering dust anywhere. Sure there is variance but about 4 to 6 weeks might be a good estimate. Best to find someone with a Fremont built car with those numbers.
Norm J |
I had an all original 40,000 mile '65 built in November '64, engine was October '64 with early '64 plug wires. Date codes are for plastic chevy people. |
Another person who has problems with how others restore their cars.
Norm J |
The Following 2 Users Say Thank You to tripower For This Useful Post: | ||
I still also owned an all original 40,000 mile late '64 built '65 with early '64 plug wires. How's that for date codes. |
I’m pretty sure I know how it works. You’re just being an for ass telling the OP he is a “unicorn” for his interest in finding the engine he wants for his car. Whatever a “unicorn”is to you. You can enlighten us.
Norm J |
The Following User Says Thank You to tripower For This Useful Post: | ||
A couple of examples. It sounds like you are trying to make your classic automobile as “correct” as possible. Correct equates to desirability and value these days with anything. Good for you! I do think that gap of around two months in your case is to much. However if that 65 motor is reasonably priced I would snag it anyway. The GTO’s in my signature are as follows, 1965 - Baltimore Built, First week of Nov. 64. Engine block, Sept. 14, 1964. Important note, GM had a nation wide strike for about a month (Sept. 25 through Oct. 25). I assume this strike interfered with my 65 Build. Take away that month of stoppage and my gap would be around 3 weeks. 1966 - Fremont Built, Second week of Jan. 66. Engine block, Dec. 29, 1965. Around 2 weeks. Yes, I agree that the engines were on the move quickly. Chris.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
Thanks guys, I was thinking two months might be pushing it too but I just wanted to hear some other opinions on it to have a consensus. I'll keep looking unless someone with a Fremont car chimes in with different numbers.
tripower, please don't let ignorant comments like the 3rd post get to you. You're right in that he has problems, either he can't comprehend my question or for some reason believes I'd be interested in his unrelated opinion. Regardless, people's comments like that aren't worth responding to in person or on a forum but I do appreciate your input so thanks again. |
If you are a GTO Salesman, get the dates perfect.
One less question asked by the "Numbers People" who might want to buy the car the GTO Salesman is selling. If you are a GTO Owner and are keeping the car FOR YOU and the engine is a good deal and will give YOU (the car owner) good service for several years, buy the engine and install it. I personally am not a Numbers Guy but I do enjoy reading the GTO History like the Nationwide Strike Info. Tom V.
To the OP..... If the part numbers are correct, that's all that matters. Unless you think you are going to be at a car show where they pull your engine apart and bust you for not having the correct date coded pistons. |
Greg, I have done no research on '68 block dating.
But I can say that EUN 088529 is a pretty early '68 Engine Assembly. In '64, that EUN was assembled by about mid-October. '64 they produced just more than 600,000 engines during the entire Model Year. '68 I think totaled more than 800,000 and they may have begun '68 Engine Assembly a bit earlier than in '64 so that I would have expected 088529 to have been assembled even earlier that year. The H167 would seem reasonable for the block but I think the EUN makes the head cast dates problematic. Since I have no data to compare to, you would need to check other early EUNs to see if early Oct dated heads make sense for EUN 088529. For example, if EUN 100000 was installed in a car built before the end of Sept., you would know the Oct heads were impossibly late for EUN 088529. Have you compared the partial VIN stamp to others from the same Plant in '68? Are you confident the partial VIN is not a restamp? I can't say one way or the other, to get a better idea you would need to obtain some data and look very closely at the partial VIN stamp. |
I'm a numbers guy, not because I place great value in them but because I am fascinated by them.
I don't have any special insight for '65 but I have an extensive log of '64 engines by Engine Code, block cast date, Engine Unit No., and where the engine could be determined to be original, the Time Built code, Car Model, and Final Assembly Plant. As my log shows, most '64 blocks moved pretty quickly from foundry casting to engine plant assembly, to final plant, and then installation into a particular build. It is pretty easy for me to make a pretty close estimate of a block cast date from the '64 EUN in most cases. I have uncovered anomalies but they are exceedingly rare. I can also generally ferret out obvious restamps with the data I have. As to the "lead" time between the block cast date and installation in a build, the norm is pretty short. But again there are exceptions. The longest lead time that I have logged for '64 was for a 4 bbl 326 HO optioned Lemans built at Fremont. For '64, the Fremont PHS records identify the original EUN. This particular engine was assembled in March as made obvious by the EUN, the block cast date was mid March but the car it was installed in was built at Fremont in very late May, approximately 9-10 weeks after the engine was assembled and 10 weeks after the block was cast. The 326 HO was a far more rare option than the GTO option so that would be one explanation for why this particular engine languished in inventory for as long as it did. However, not all 326 HO engines exhibit that kind of spread so more likely it was just an anomaly. Without the Warranty Booklet or some other documentation to show the original EUN, nobody can really know if an engine is correct based on cast date. I usually advise that as long as the Engine Assembly existed at the time the car went to final assembly, anything is possible. Some are more plausible than others, but that is a minor quibble in my book. I have not logged any '64 GTOs with such a spread but that doesn't mean it didn't happen. I used to believe that the satellite plants such as Fremont would typically show wider spreads than the home Pontiac Plant. However, it turns out that even this isn't necessarily so. A 2 month spread for your May built GTO would be unusual (at least in '64 but probably also true if you logged '65 data). But I wouldn't say it wasn't possible. Just my opinion! |
Until the "word" got out many "Trophy Hunters" were passing their 421 cid blocks/ engines off at the car shows with a simple "Its a stock 389" comment. But I never was a "Wood Hunter" but if that is your pleasure, go for it.
Now John V's "Obsession with Numbers" is perfectly normal. My "Obsession" is with Boost. Tom V.
I'm not so sure about that.
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
LOL
Keith and Tom, with friends like these....
Numbers are (mostly) rational. People? Not so much! |
I have the largest time gap I've run across yet on my '68...I know it's not a '65 but still interesting I think to this thread.
Car was built 2nd week MAY 1968...engine and heads are October and November of '67. 7 months....Yes, numbers match, EUN, partial VIN on block and frame rail. Anyone seen a gap bigger than that? How 'bout it John V.?
Greg Reid Palmetto, Georgia Last edited by Greg Reid; 03-01-2018 at 02:16 PM. |
