Need help trying to locate correct engine color paint for 78 and 79 6.6 T/A engines standard corporate blue is not correct .Corporate color would be correct for 403 engines and chevy 305, 350 engines thanks
Corporate Blue was the stock color for my 77' 400. Why would 78 be any different?
461 Cu. In. Pure Pontiac Power: 1969 Pontiac GTO - Back On Top - Popular Hot Rodding Magazine |
Corporate Blue is as close as you can get to out of the can. My 78 was slightly more green, still got the valve covers to compare. Not as green as soem of the 73 SDs were.
![]() Quote:
I knew I wasnt going crazy,,, anyone know where I can get it??? |
Have you tried Eastwoods?
I've seen corporate blue from Dupli Color in the local parts stores and Walmart.
Warren |
John Witzke has previously posted this formula for the 1977-78 W72 Engine color. It isn't available anywhere off the shelf. You have to get a paint shop to mix it up and put it in a rattle can for you. I understand that this was color matched from an unexposed bit of paint off an original W72 engine.
Tinting Guide Mix size: Special (6.25 % of gallon) 8.0 oz 2K-553 Brilliant Blue 61.2 2K-010 White 179.7 2K-024 Ochre 240.2 2K-550 Violet 246.3 2K-011 Black 258.9 NON-CUM Guide 2K-553 Brilliant Blue 61.2 2K-010 White 118.5 2K-024 Ochre 60.5 2K-550 Violet 6.1 2K-011 Black 12.6
Steve 1978 WS6 W72 4 Speed Trans Am - Martinique Blue on Light Blue - Fire Am Restification Project 1972 4-Speed 455 HO Trans Am - Original Cameo White on Blue car - Restoration Project |
Thank you.. this will help out alot
I would like to clarify, 1977-79 L78 and W72 engine appears to be the same color use by the other GM divisions. I am sure it is GM Blue originally used back then, however, I have stated in the past and stand by what I have stated, the GM blue paint found in many of the aftermarket paint companies spray cans is too blue for correct factory appearance.
John Witzke POCI Tech Advisor 1977-79 W72 Performance Package Historian |
![]() Quote:
Very early 1977 cars engines were the same shade of blue used during 1976 model year, then a change to the blue used for the remainder of 1977 and on.
Here is my 1977 W72 with 11,300 original miles from new.
Here is a picture of a ultra low mile 1976 455. This shade of blue was used on early 1977 engines. I am not sure of the switch over date to the shade of blue found on mine (see above) occured.
Here's an interesting chart.
http://fiedlerh.home.att.net/enginecolor.htm Unfortunately ALL of the 77-81 Corporate Blue chioces are close but no cigar! Now you can pick your favorite "incorrect" color. You'd think that one of these companys would take the time to "get it RIGHT!" |
