Old 11-15-2009, 05:56 PM
wheelspin's Avatar
Smile Survivor no more..........
Well, after watching the surface rust on old GTO's horizontal panels worsen each year, and the original interior split and fade to the point where even my wife said "it's time to restore the Goat", I pulled it apart and took it to Auto Perfections in La Habra for a body on restoration. Having been assembled in Fremont CA and never leaving SoCal, the rust free (w/ the exception of surface rust on the trunk floor, the front footwells, and the bottom of the rear window) sheet metal should be an easy job after the usual door dings are pounded out.
First surprise on this original car was that the front clip had been replaced w/NOS panels @ some time in it's past (see black primer vs red oxide on body). No visible frame or cowl damage, or anything else to indicate a collision, leading me and my bodyman/painter to surmise that it may have been damaged on the assembly line or in transit. Whatever happened, my painter said that the entire car was painted in laquer, presumably after the front clip was replaced.
Gonna miss my "Survivor" .
Les
ID:	187697   Click image for larger version
ID:	187698   Click image for larger version
ID:	187699   Click image for larger version
ID:	187701   Click image for larger version
Les Iden
Old 11-15-2009, 06:46 PM
Blue '66's Avatar
Blue '66 Blue '66 is offline
Very envious as I continue block sanding my '66 GTO again and again.LOL!Looks geat Les!
Old 11-15-2009, 07:07 PM
tom s tom s is online now
will you still let me park next to you when its done?Tom
Old 11-16-2009, 02:10 PM
wheelspin's Avatar
Arrow Project coming along..........
Thanks, man.
Tom, I would be happy to have any of your special Pontiacs parked next to mine, even when it's done .
Les
Les Iden
Old 11-16-2009, 05:58 PM
Ron Landis's Avatar
Question Cool!!!
Yet another post car! What is the original color on that one? Ron
Old 11-16-2009, 07:09 PM
george kujanski's Avatar
I believe it's the '66 in his avatar.
George
Old 11-16-2009, 08:11 PM
wheelspin's Avatar
Smile George is correct.........
Painting it Reef Turquoise, the original color.
Les
Les Iden
Old 11-17-2009, 03:47 AM
INJUNTOM's Avatar
INJUNTOM INJUNTOM is offline
Nice
Old 11-17-2009, 01:55 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Les,
The rear window panel...is it the available repro or did the shop recreate it themselves?
Mine was rebuilt in the '80s (when no reproduction was available) & had some mud in it. Now that the car has been together for a year or so, you can see where some of the bodywork was done. I'm considering having that panel replaced. I talked to my body guy & he really doesn't want to repair what is there & told me to order the replacment & he will install. I plan to do the drain tubes as well. It appears that the water just lays in there & it must be getting under the 20+ year old bodywork in this area.
My real question is...how well did it fit? Was your body guy happy with it?
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
Old 11-17-2009, 08:35 PM
wheelspin's Avatar
Thumbs up Rear window panel.......
Hi Tod,
My bodyman said that the repop rear panel worked great, was the same gauge as the original, and he was impressed with the finished repair. He also installed the recommended drains that you mentioned. I am told that that there used to be a smaller repair panel (only the bottom rear glass channel and 3-4" deep/pictured in the PY catalog, but unavailable) which eliminated the need to remove the two factory leaded seams.
Les
Les Iden
Old 11-17-2009, 09:43 PM
GT182's Avatar
GT182 GT182 is offline
Don't feel bad about what you're doing Les. It's still a "survivor" because it's still around and not in some scrap pile or cut up for parts. It's just not as original as it once was, but it will thank you for the face lift and care you're giving it by being around to enjoy for many years to come.
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
Old 11-18-2009, 08:21 AM
6 Grrrs's Avatar
Originally Posted by wheelspin View Post
Hi Tod,
Les
Les,
I'm assuming you got the repair panel from PY?
Part # RPR151 @ $89?
Tod Hoffmann
2002 Honda VTX1800C
Old 11-18-2009, 12:06 PM
wheelspin's Avatar
Originally Posted by 6 Grrrs View Post
Les,
Tod,
Actually, the panel came from Ames, part #L174H $99, since I won a $100 certificate @ a local car show. Judging by the price, I'm guessing that they are the same part, even though Ames is 10% higher . There were no stickers or identifying marks on my piece.
Les
Les Iden
Old 11-18-2009, 01:44 PM
6 Grrrs's Avatar
Tod,
Les
Thanks for the info.
Tod Hoffmann
2002 Honda VTX1800C
Old 11-17-2009, 10:17 PM
You know that this means Les?
It's time to buy another OE paint car for a beater!
former." --Albert Einstein
- Winston Churchill
Old 11-18-2009, 02:17 AM
wheelspin's Avatar
Cool Daily drivers...........
Hey Mike,
You know better; shiny paint is not going to keep me off the streets/highways .
Les
Les Iden
Old 11-18-2009, 08:25 AM
67GTONUT's Avatar
67GTONUT 67GTONUT is offline
I went thru the same thing when I decided to paint mine..... but my decision was easier, it had a 1-2 partial paint jobs in the past..... top half of car was painted once.... and then at one point in its life.... it had the trunk and tail restored.... so it was painted in the rear and blended forward....
Glad I did it.... and so will you be....
Good Luck.... Cant wait to see the pics!!!!
Troy
Rockaway NJ
67 GTO
400HO / TKX 3.27 1ST GEAR-.72OD / 3.36 POSI
HOTCHKIS/UMI/BILSTEIN
Old 11-18-2009, 09:30 AM
Rugratman's Avatar
Rugratman Rugratman is offline
Les, no interior work?
........I'm just learning as I go.......
Old 11-18-2009, 12:22 PM
wheelspin's Avatar
Question New interior......
Rug,
My original interior was in usable condition except for splitting seams on the driver's bucket seat and the usual fading. I replaced the bucket seat foams, armrests, dash wood panel, padded dash pad, and carpet eight years ago and the headliner was replaced four years ago. New bucket seat covers were not going to match the colors of my faded & worn interior.
I opted to replace all of the interior with new stuf purchased from Legendary, the manufacturer, in order to get all of the pieces made from the same dye lots.
Les
Les Iden
Old 11-19-2009, 11:27 AM
66GTO Jim's Avatar
66GTO Jim 66GTO Jim is offline
Rug,
Les
Hey Les,
Unfortunately, I had an outside seam split on my drivers seat recently. Since the car has its original interior, I am really going back and forth on replacing the whole interior or just leaving it the way it is. Seats are not faded, which is amazing for a 66 Convertible. I have heard that the Legendary Interiors are the best out there, but have not seen their product in person. How close is it to the original Morrokide interior? Are the lines as deep as the original etc? Any info would be appreciated!
Thanks... Jim
"Never try to teach a pig to sing. It's a waste of time and it annoys the pig"
