What kind of performance can be gained from converting a 1bbl to a 4bbl using the 1bbl head? I would assume that changing out the cam to 4bbl cam would be necessary right?
![]() 69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
Both my OHC engines are going to be using 1bbl heads for compression reasons. First one will be using the 4bbl intake, second engine will have a custom intake. Other than compression (chamber depth), the ports are essentially the same with minor differences to account for the chamber shape difference (shorter versus longer inside radius).
My first engine will be first tested with a used 1bbl cam incase something goes wrong, but shortly afterwards I'll swap in a new 4bbl E cam. As for actual performance gains, I'd expect some, but I don't know the actual amount.
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
it will be baby steps with each item
it was the whole package that made 60 more HP I would run the 1 bbl head and cam with 4 bbl intake and exhaust to get a temporary motor while yours is freshened up. This way youre not opening up a can of worms.
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
![]() Quote:
The block/rods/crank/pistons/oil pump/ are all the same I can transfer the dizzy/coil/intake/exhaust/fuel pump to the 1bbl block I can install a regrind "H" cam that I was going to buy anyway What I would need is to find a 4bbl head. I am guessing that a 68 or 69 redone should work. What am I missing?
I have not converted a 1bb to 4bbl, but I have owned and driven both. The difference in big time noticable.
I wish I would have gone to the "6=8" performance recommendations with my 66 Tempest Sprint. |
balancer too
you could do all this but I was thinking you wanted a temporary motor to use while yours was being freshened up. Swapping intake and exhaust and nothing else is an easy fix. Be sure and do a compression and leakdown test on the donor before you get real excited about it.
![]() Quote:
Here's a picture of the motor I picked up today. The balancer on it is a two groove and "looks" even fatter than the one on my Sprint. I'll have to measure them to compare. http://i263.photobucket.com/albums/i...105_164037.jpg I do want a temporary motor but when I started going over everything I would need I wanted to know what it would take to do a complete conversion.
Are you going for a true sprint conversion? Yes the balancer is a bit larger for the Sprint engines, supposedly for the extra rpm since the rotating assembly is the same.
How out curiosity, where are you getting an H cam from? I thought only 4bbl E's were available?
![]() Quote:
Same balancer thats on my 69' looks like the marks are in alighnment.
Do you have a Sprint balancer? I believe the diameter for a Sprint is 8 11/16.
![]() Quote:
Im also going to use the 4bbl set up w/ a 1bbl head lower compression. I have a new 1bbl cam that I will be running for a while but plan to change over to the 4bbl E cam down the road. |
![]() Quote:
If you get one ground, find out what the cam core diameter was cut too versus a stock cam, then take half that diameter change as how much needs to be added to the valve stem side.
BIG CHUNK O METAL
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. ![]() Last edited by Jeff Hamlin; 04-20-2014 at 09:38 AM. |
Mark,I guess you already know what your 69 Sprint balancer looks like.
They are getting very hard to find in nice shape. I would do a freshen up of the 1bbl with new seals and gaskets,add 4 bbl intake and exhaust and have some fun. If it blows up,you havent ruined a #s matching block. Prep you old motor for long term storage and collect new parts for a rebuild.
Before cams were reproduced I was regrinding H grinds.
1st choice was an H grind with minor scuffing,nest was an E grind ,same. Last was a clean 1 bbl.I m not sure if I have any left or not. Mostly cut the covers to match what was removed off cam.
Ah, yes, shaving the covers works too. Of course the cam timing then gets slightly retarded (and more so if the block is decked) unless you have a Sprintbird timing sprocket or something similar.
![]() Quote:
You can even get elaborate and use an offset bushing to change the cam timing.
