What's the Lowest Gas Mileage Car You've Ever Driven?
I remember reading how a 73 Trans Am had an EPA Fuel Estimate on its sticker of 8.
I was wondering what's the lowest mileage you had for a car you owned or currently owned? As I was contemplating doing a 535 for my 69 GTO and was thinking how a motor like that is likely good for 5-6 mpg, was just thinking out loud. |
Alot of the original EPA mileage figures on these cars were given with factory crappy tunes that had emissions in mind more than economy so I take all that with a grain of salt.
Worst I've had is about 10 mpg out of a 600 HP 454 that I currently drive, with 4.10's and no overdrive. That's after alot of wideband tuning in the part throttle areas to achieve that, and normal driving. Bigger cubes get pretty thirsty though. My fathers 571 he's driving on the street with over 700HP, he's reporting about 5 mpg with 3.73's and no overdrive. But the tuning is fresh off the dyno with no part throttle tweaking as of yet. I feel there might be 1-2 mpg in it but it's going to be tough on fuel either way. Converter needs tightened, and may drop the rear gear to 3.50'ish when the rearend is done again. The fun factor far outweighs the fuel mileage, and building these engines to run on pump gas is what makes them affordable to drive. |
A 1990 Ford F250 with a 460, was getting 5-6 mpg.
LOL, Sometimes I wonder how some of that stuff could be that bad.
My current 79 1 ton 454/400 turbo with 3.73's gets 14 mpg, and with it's current 502 crate motor it's getting 11-12 mpg around town. |
My Chevy pick-up gets around 10 on a good day. Averages around 8 normal driving. My GTO only got around 7-8 when I was running the Holley, gets around 12 with the present Q-jet. GP has gotten about 18 on a long drive.
1971 GTO,72 400, stock bottom end, 670 heads, Lunati BMII cam, headers, iron intake Q-jet, four speed. Best 60 ft 1.806in 2004. Best 1/8th mile e.t. 8.46 with 3.55 open rear 85 Grand Prix, 70 400, casting 62 heads stock rebuild, Turbo 350 trans 78 800 cfm Q-jet modified as per Cliff Ruggles book. 87 F350 6.9 4 speed dually A poor man has poor ways. |
94 F350 351w on 35's gets around 9mpg. Good thing both tanks work!
"Those poor souls have made the fatal mistake of surrounding us. Now we can fire in any direction" 1970 Trans Am RAIII 4 speed 1971 Trans Am 5.3 LM7 1977 Trans Am W72 Y82 1987 Grand National |
'93 Bronco w/ a 5.8 (351), E4OD, 3.55s with 30" tires got around 12mpg unloaded, got 9mpg from CO to CA towing a 65 GP.
Once the snow starts flying and I have the blade on it the mpg's go out the window.
My 1970 Judge 455 .030" 744 cam TH400 3.55:1 225/70x14 got 10.5 - 12.3mpg
My 1966 Tripower 400 .030" 068 cam TH400 3.07 215/75x14 got around 16mpg. |
'78 Macho T/A DKM#95, 460cid, SRP pistons, KRE 310 D ports, 3" pypes, Hooker 1 3/4" headers, hydraulic roller, 10" Continental, 3.42 gears 11.5 @117.5mph 3900lbs ([_|_] ##\|/##[_|_]) |
Did the Emissions and F.E. side of the business for several years. The old EGR stuff and other add-ons were basically band-aids until the Research People and Automakers could come up with proper systems. Then: 78 Trans Am (11 City and 15 Highway) was the best for me but the engine was untouched with all of the stuff still on it. 64 GTO Tri-power actually got better mileage (but was lighter too). Tom V.
My GTO (389, tripower, 4 speed, 4.88:1 gears) gets about 4 mpg.
My Chevelle (555 cu in, approx 900 HP naturally aspirated) takes about one gallon of Torco 110 per 1/4 mile pass. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
I'd say my drag racing car. 4 gallons to the mile........
My one ton Dodge van is heaven compared @ 10 MPG on a good day. Race car $12.00 gallon - Work van $2.85 a gallon!
I drove a Uhaul box truck towing my car on a trailer from Tampa to California. Averaged about 7.8 mpg. That was an expensive move...
Mom had a 72 Country Squire wagon with a 400 2 barrel back in the day. The word combo "gas hog" was created for it.
frittering and wasting the hours in an off hand way.... 1969 GTO, 455ci, 230/236 Pontiac Dude's "Butcher Special" Comp hyd roller cam with Crower HIPPO solid roller lifters, Q-jet, Edelbrock P4B-QJ, Doug's headers, ported 6X-8 (97cc) heads, TKO600, 3.73 geared Eaton Tru-Trac 8.5", hydroboost, rear disc brakes......and my greatest mechanical feat....a new heater core. |
Didn't pass many gas stations, did it? Dad's '66 Country Squire with a 390/4bbl/3.70 gears(towing package) got 8-10 mpg. The worse one I've ever drove was a friend's 289 Cobra. If I recall, Chris said it got around 6 mpg.
78 Chevy full size PU, 350 4bbl auto, original engine. Would get 12mpg highway, city, 80mph, 30 mph, empty, full, uphill, downhill. You could throw it out of a plane and it would still get 12mpg.
It defied everything I learned about physics and the conservation of energy. JohnnyB |
