Performance Parts For Sale/Wanted Just Performance, non-stock, trailers, tools and related accessories here.
Old 01-01-2020, 09:10 PM
RUDOLFSSON's Avatar
RUDOLFSSON RUDOLFSSON is offline
Default The Big Brace is here. A new lifter wall support kit F.S.
Hello Pontiac world.
I'm currently taking orders on my new lifter wall support kit. Digitized from a #481988 PMD block and will fit 70's era blocks better than others.
This kit will both act as a support to all the weak lifter walls of the Pontiac block and will also keep unwanted parts from hitting the rotating camshaft in case of a valve train failure. All traditional Pontiac roller lifter applications create side loads on the lifter walls of the block and therefore I recommend this lifter wall support kit in all serious rebuilds.
Kit includes 4 cnc machined billet aluminum blocks, full custom fastening kit and worldwide shipping for $399 via paypal.
Thanks,
Kristinn
Please click pics for larger copies
*** THE BIG BRACE is here ***
The Following User Says Thank You to RUDOLFSSON For This Useful Post:
Old 01-01-2020, 09:13 PM
694.1 694.1 is offline
Impressive!
Still have my 1st Firebird
7th Firebird
57 Starchief
Old 01-01-2020, 09:22 PM
HoneyHush HoneyHush is offline
Very nice.
Old 01-01-2020, 09:55 PM
Mike Davis's Avatar
Nice product.
66 GTO Nostalgia Super Stock/Street Legal Car
421 CID, stock block, Wenzler Intake, 2- Carter 750 AFB's, 3.90 Gears, Full Factory Interior, Full Exhaust, Stock Suspension 3750LBS 9.77@136.99
66 GTO 389 3x2, 4 speed, 4.33 gear, Montero Red 33K original Miles
Old 01-01-2020, 10:32 PM
jimmy daniel's Avatar
jimmy daniel jimmy daniel is offline
If I still had a stock block I’d have to have this. Nice piece!
1965 TriPower GTO, 1967 GTO, 1969 GTO, 1969 Judge, 1972 GTO, 1977 Smokey and the Bandit, 1989 TA ProStreet, 1968 Firebird NHRA 10.90 racecar, 1963 Tempest S/Gas
Old 01-02-2020, 02:16 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Is any drilling/tapping or grinding of block needed?
Old 01-02-2020, 04:38 AM
RUDOLFSSON's Avatar
Thanks for the kind words.
Your Pontiac block will need prep work and the support pieces will also need some grinding, depends on the block. They can vary by quite a bit.
Block will also need four 5/16-24 drill & tap operations, please see attached file in the first post.
70's decade blocks have the nicest fit as machined in my findings...
Kris.
Old 01-02-2020, 07:06 AM
RUDOLFSSON's Avatar
edit :
70's decade blocks have the nicest fit with the supports as machined in my findings...
Old 01-02-2020, 12:26 PM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Nicely done!
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
Old 01-02-2020, 01:45 PM
So what address to order/Paypal?
Old 01-02-2020, 02:37 PM
Mike Kasparian,Sr.'s Avatar
Mike Kasparian,Sr. Mike Kasparian,Sr. is offline
Well thought out piece , very nice . Will keep you in mind for future builds .
505 CID, 3560 lbs,Tiger heads, NA.
8.99@149.8 mph, 1.29 60', stock suspension
Old 01-02-2020, 03:20 PM
RUDOLFSSON's Avatar
PM for business, please.
Old 01-02-2020, 04:19 PM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Looks like a solid solution to the age old problem...sharp looking setup. Will keep in mind for future work. Best of luck.
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
Old 01-02-2020, 04:53 PM
AIR RAM AIR RAM is offline
I am interested... sent you a PM.
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
Old 01-02-2020, 05:36 PM
Dragncar Dragncar is offline
Question, what is holding all this down ? Is it based on the two 5/16 bolts for the valley cover. Is there any drilling or tapping required like the KRE brace. I bought one of those and never used it because I did not want to drill and tap right on top of a cam bearing. So I bought the basic SD brace.
I have a full SD brace for the build I am doing now. Is there any epoxy used to take up space like the SD brace ? I do not see any of the steel plates that go under and "clamp" from top to bottom.
Nice looking piece
Old 01-02-2020, 07:03 PM
RUDOLFSSON's Avatar
Hello & thanks for the interest. I have a revision B install guide in the works showing baby steps on the prep and install.
The kit has a total of 6 bolt forces acting on it plus a full epoxy bond on each aluminum block all around.
The kit requires 4 drill and tap locations 5/16-24. No drilling or tapping into the cam bores needed.
Drill & tap locations as follows:
1. Front of block, through hole. Utilizing the small billet steel banjo bolts and set screws acting on the aluminum block.
2. Front of lettering pad (cubic inch lettering pad 00/50/55).
3: Rear of lettering pad.
4: Rear of block, through hole. Same deal as the front
ID:	528049   Click image for larger version
Old 01-04-2020, 05:42 PM
62cat421sd 62cat421sd is offline
i will take 2 vance vwh1962@hotmail.com
Old 08-02-2021, 05:41 PM
276tas 276tas is offline
Do you accept Paypal
What do you mean by the last line
Nota bene..these are aimed @ the #48XXXX blocks.??
Old 01-16-2020, 08:14 PM
RUDOLFSSON's Avatar
Thumbs up
New install guide out, REVISION B.
Thanks to all that bought their first sets and the support.
I've included here my install guide as image file bundle for your ease of viewing. PM or email for better resolution PDF file.
Kris.
Old 02-27-2020, 07:04 PM
RUDOLFSSON's Avatar
2 sets on the shelf ready to ship.
Kris.
