Old 01-06-2020, 10:44 PM
slowbird's Avatar
slowbird slowbird is offline
Default Flow comparison
Just thought i'd add some tech to the board, maybe generate some discussion.
Valve sizes on the heads ranged from 2.28 to 2.365. HP heads have made 1050 horespower with 1 carb and a cam that is gental on valve springs, other heads have not been run yet.
..........HP / PP / Tiger
.200 125 142
.300 194 218 221
.400 266 292 287
.500 334 349 367
.600 387 402 421
.700 417 446 453
.800 425 470 466
.900 428 477 478
1.00 430 480 484
Old 01-07-2020, 01:03 AM
Scott Stoneburg's Avatar
Do you have dimensions on the ports for each? Port opening...CC of the port...
Were the heads all ran on a motor or just the HPs?
Old 01-07-2020, 07:51 AM
Thanks for posting, and what's your plan for these heads?
I really wish you had the flow numbers for the Tigers @ .200" lift and the max port area for each head and the info of how many cid of a motor these heads where going on?
The flow numbers at .200" lift are just as important as max high lift when Exh scavenging depressions are added into the equation at overlap!
Looking at what you posted the PP heads will make for a nice gain in Hp over the high ports and the Tigers will do even better if there port area is not too much for your cid, but with the Tigers you will need a Carb of for example 1150 cfm or better if your had been running a 1050 type dominator.
Most motors that can breath deep enough to make over 1000 hp on a single Carb will gain 25 to 30 hp with duel Carbs on a Tunnel ram it seems.
Thanks again!
Old 01-07-2020, 09:46 AM
PAUL K's Avatar
PAUL K PAUL K is online now
Do you have exhaust numbers?
Go fast, see Elvis!
Old 01-07-2020, 03:35 PM
opeliac opeliac is offline
Ok, call me dumb...What are PP heads?
Old 01-07-2020, 04:07 PM
mysticmissle's Avatar
pro port eheads
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 01-07-2020, 06:05 PM
slowbird's Avatar
Ex flow
.........hp / pp / tiger
.200 114 108 107
.300 157 159 148
.400 197 197 187
.500 228 227 221
.600 247 248 247
.700 255 259 263
.800 262 266 276
.900 267 271 284
1.00 270 275 290
Port opening
HP 2.62x1.48
PP 2.65x1.65
Tiger 2.70x1.60
Old 01-07-2020, 06:57 PM
Nice numbers...you have a lot tied up in those 3 sets of heads...
Old 01-07-2020, 07:15 PM
PAUL K's Avatar
Nice numbers...the Tigers have the most power potential but the Pro-ports would be the best all around head. The Hi-ports will make big power also.
You get them at the neighborhood garage sale
Go fast, see Elvis!
Old 01-07-2020, 08:18 PM
slowbird's Avatar
Not sure i agree with you on the pro ports, there is a reason they are no longer available imo.
Old 01-07-2020, 08:51 PM
PAUL K's Avatar
That's okay you don't have to agree with me. I just thought I'd let you know how they stack up.
Go fast, see Elvis!
Old 01-07-2020, 07:20 PM
Who ported each set? Are they CNC'd, or hand ported?
Old 01-07-2020, 08:19 PM
slowbird's Avatar
Dan Barton ported all of them, mix of hand porting and cnc ported
Old 01-07-2020, 08:52 PM
PAUL K's Avatar
Dan does good work!
Go fast, see Elvis!
Old 01-07-2020, 09:24 PM
slowbird's Avatar
Dan does good work!
Yes he does!! One of the best imo!
Old 01-07-2020, 10:41 PM
Dan is a very sharp guy... he understands induction...
Old 01-07-2020, 08:53 PM
Based on those flow numbers...
In your opinions...Which heads would be better on a 480" turbo combo with a .650-.700 lift camshaft? Max power mindset.
Old 01-07-2020, 09:05 PM
PAUL K's Avatar
Hi-port head
Go fast, see Elvis!
Old 01-07-2020, 09:08 PM
Hi-port head
Why did you pick those?
Old 01-07-2020, 10:43 PM
PAUL K's Avatar
Not sure I want to go into a lot but detail but to be safe the Hi-port will have a more reliable valvetrain and has the best I/E ratio. I'm sure all three heads would have a ton of power potential.
Go fast, see Elvis!
