Old 02-04-2020, 11:35 AM
mysticmissle's Avatar
Default 2020 1000 hp e head combos
how many documented, even with loose dynos or down hill tracks are there? I'll take the under at <7 Naturally aspirated.
Secondly Why would you, did you try and do it when there are better options in available?
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 02-04-2020, 11:43 AM
PAUL K's Avatar
PAUL K PAUL K is offline
What are the better options and why are they better?
Go fast, see Elvis!
Old 02-04-2020, 12:34 PM
Stan Weiss's Avatar
OK lets make a list of who has done it. Here are a couple to start.
Jeff Kinsler
Mike Leech
Stan
Pontiac Pump Gas List
Old 02-04-2020, 12:40 PM
PAUL K's Avatar
Jeff Kinsler
Mike Leech
Stan
In Spirit of this thread should we make a list of all heads that have broke the 1000hp? I think Mystics estimate might be close but I'd really like to know about the better alternatives and why they are better.
Go fast, see Elvis!
Old 02-04-2020, 01:16 PM
[QUOTE=PAUL K;6107111]In Spirit of this thread should we make a list of all heads that have broke the 1000hp? I think Mystics estimate might be close but I'd really like to know about the better alternatives and why they are better.[/QUOTE
Do we agree that there are more
1k plus hi ports than 1 k plus eheads?
More 1 k plus tiger builds than eheads and i would expect all others combined?
just conjecture but more quanity may be an indication of ''easier'' or more available
i think we are up to 4 or 5 1k eheads that we know of
Jammel Gabby build
Kinsler
Lil Jack? not quite?
people from up north
Mike L
1964 540 gto
Old 02-04-2020, 01:41 PM
PAUL K's Avatar
[QUOTE=mysticmissle;6107129]
Jammel Gabby build
Kinsler
Mike L
No I don't think there are more 1k Hi-port engines out there than E-heads.... I could be wrong though.
Gary H on here made over 1k with E-heads.
The double thing I mean.... I think if you added up all the Pontiac NA 1k builds with other heads there would be more than double the amount of E-heads that made over 1k (NA/& power adder).... Again I could be wrong. I don't keep track of this stuff.... Maybe Slowbird will chime in he pays more attention.
Go fast, see Elvis!
Old 02-04-2020, 12:41 PM
how many 1 k eheads are you aware of? tigers, hiports and warp 6s jury is out on any set of 5 style head, CVs and Super wedges, being ''easier to make 1 k'' in my opinion. RPM should also factor into this, but
I am no expert, Im a just a lowly knuckledraggin, bracket racing, ehead owner struggling to make 850 hp reliably. If i was trying to make 1K i think would be buying a different set of heads. A build similar to Tom Kilroy's would be an excellent starting point for a 1 k hp Pontiac powered bracket car
1964 540 gto
Old 02-04-2020, 06:42 PM
AIR RAM AIR RAM is offline
I am no expert, I'm a just a lowly knuckledraggin, bracket racing, ehead owner struggling to make 850 hp reliably. If i was trying to make 1K i think would be buying a different set of heads. A build similar to Tom Kilroy's would be an excellent starting point for a 1 k hp Pontiac powered bracket car
What cc are your eheads and what do they flow? How much lift are you running? What RPM range are you making your 850hp at? I have always liked your set up... 850NA is no small feat!
The key words that you mentioned is "850HP RELIABLY"... That's a tough requirement to achieve the higher up in HP you rise. However, (off topic) 5lbs of boost should get you there... LOL
SPEED SAFE, NICK
"The grass is not greener on the other side, its just fertilized with different $h!t"
The Following User Says Thank You to AIR RAM For This Useful Post:
Stan Weiss's Avatar
Not sure if "E" head or Pro Porter
John Marcella
Stan
Old 02-04-2020, 12:53 PM
PAUL K's Avatar
John Marcella
Stan
Pro-port JM ran
I believe they've done three more E-head (after ML) engines that broke 1k (well I think one of those were pump gas deal missed by a couple)... Not sure if that counts.
Jimmy Jamal made North of 1k. You could really blow this list wide open if you want to include power adder combos. I think they'd be more E-head combos out there to add up to more than all other NA engines combined.
EHTTFMF!!!
Go fast, see Elvis!
Old 02-04-2020, 12:47 PM
who are the canadians witht he greensih tempest? I think they ran Heads up class with wide ports and made 1k
1964 540 gto
Old 02-04-2020, 12:58 PM
PAUL K's Avatar
Is it okay to call the Canadians? Nowadays you don't want to hurt any feelings. Maybe the next country North would be safer.
Go fast, see Elvis!
J.C.you's Avatar
J.C.you J.C.you is offline
We made 1000lbs torque with v heads, that count?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 02-04-2020, 01:00 PM
PAUL K's Avatar
Sure why not? .... But it's not my thread. I'm just anxious to learn something.
Go fast, see Elvis!
Old 02-04-2020, 01:07 PM
no not for this thread lol. did you still have that boat anchor or did you sell it? No i cant afford it.
1964 540 gto
Old 02-04-2020, 01:01 PM
Stan Weiss's Avatar
What heads did Brian / Slowbird make 1000+ HP with?
Stan
Old 02-04-2020, 01:03 PM
PAUL K's Avatar
Stan
Hi-ports
Go fast, see Elvis!
Old 02-04-2020, 01:19 PM
Stan Weiss's Avatar
Looking at a dyno sheets I have saved.
Tom Syron - 999.1 HP
Anyone know what heads he runs?
Stan
Old 02-04-2020, 01:22 PM
cv whats
1964 540 gto
Old 02-04-2020, 01:42 PM
catalina_dream's Avatar
catalina_dream catalina_dream is offline
Default Canadian Tempest
Shawn Dixon had the Tempest Paul was referring to.
1972 Firebird
462, 6X heads, RA4 cam, iron intake, Cliff's Q-Jet
3925 race weight
Best of 12.88 @ 105 so far
