If you have ever used a summit 2801 what kind of vacuum did you have?
I am sorting some things out and was curious what I could expect in the form of vacuum with this cam. Thanks for your reply Greg |
Depending on your engine and static compression you should have between 16 and 17 hg maybe even a tad more
Tim Corcoran |
![]() Quote:
13 heads 9.5:1 pontiac 1965 tri power 2801 cam w adjustable rockers cam degreed by machine shop Summit ready to run dist. adj vacuum can 12-13 inches of vacuum Still sorting alot of things out Only running center carb for start up Greg |
The car idles well now?
Little more back ground on your deal with this engine>?? Fresh rings, bore, rering or valve job, etc.? Have you driven it under load to seat the rings yet? |
![]() Quote:
Greg |
"2801 cam w adjustable rockers cam degreed by machine shop"
Where did they put it in at? Ignition Timing at idle? Deck/COmpression Ht of pistons? Valve relief CC? Gasket thickness? 13 are 72CC ...stock IIRC??? Calculating your CR. Last edited by STEELCITYFIREBIRD; 07-21-2020 at 03:50 PM. |
The Summit 2801 is very close the the original tri power cam (Melling 068). You should have plenty of vacuum to run power brakes. The only thing I see sketchy in your combo is the Summit distributor. Never had any luck with anything except an original Pontiac dist.
LEAD, FOLLOW, OR GET THE HE!! OUT OF THE WAY!!! HONEST JERRY'S SPEED AND EQUIPMENT
![]() Quote:
Greg |
Suntuned might be able to help you.
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
I run the Summit 2801 in a 400 9.25:1 compression in an automatic with 3.08:1 gear. Heads had some work done and have headers with a stock intake. Vacuum is 17.5" and is a really good cam in a 400. Best band for your buck type of deal
Something's not right. I had 14+" vacuum in a 9.25:1 400 with a comp xe274. I would expect a minimum of 16" vacuum from that cam unless your compression is really low.
---------------------------- '72 Formula 400 Lucerne Blue, Blue Deluxe interior - My first car! '73 Firebird 350/4-speed Black on Black, mix & match. |
compression check
1 167 2 167 3 160 4 165 5 160 6 155 7 162 8 167 #13 heads ccd at 77 with 7cc relief Flattop pistons I don't know any more Greg Last edited by footjoy; 07-22-2020 at 10:26 PM. |
Following both threads.
Is you vacuum steady at idle? Off idle? ~ 2k RPM? |
![]() Quote:
Idle 11 inches of vacuum 1400 rpm 14.5 inches 2000 rpm 16 |
If the needle is steady,I'd try advance the timing,
Current ignition timing? Idle RPM? Do you have vacuum advance connected? Some good diagnostic info: https://www.crankshaftcoalition.com/...gine_diagnosis Last edited by STEELCITYFIREBIRD; 07-23-2020 at 05:03 PM. |
Greg, My new 400 build has 9.94 to 1 compression, the 2801 cam, stock exhaust manifolds, 2.5" exhaust system, Q-jet carb on the stock iron intake.
It's a fresh build and still breaking in (maybe 10 miles on the engine since it was installed a few weeks ago). The heads are 1970 small valve #16's. Timing is 12 degrees initial; 36 degrees total (by 3000 rpm) and has a 10 degree vacuum advance cannister for 46 degrees total for cruise. Vacuum at 800 rpm idle (no vacuum advance) was 15.5 - 16.0 inches and we expect it to go up a couple pounds with more miles as it breaks in. The running temperature was 180 - 190 degrees on an 85 degree day. Cylinder pressure was consistent at 175 in each cylinder. The cam was installed straight up (I don't recall the intake centerline). Dennis |
![]() Quote:
I just sent the carb to Dick Boeneske to go through, it was not idling at all. I was surprised I thought my compression test would ne higher. with almost 10:1 compression. I have been following your build and am quite impressed. I found out my small valve 15s ccd at 90 cc which gave me about 8.1:1 compression on the previous build. Good to hear from you. Greg Last edited by footjoy; 07-24-2020 at 09:57 PM. |
I'm running the 068 in my 70 400. 10.13:1 compression with the original 12 heads.
I run 14 initial timing with 34 degrees total all in by 2600 rpm. I run an additional 10 degrees of vacuum advance. I installed the cam on a 108 ICL. I have a solid 13 inches of idle vacuum at 5,000 feet elevation. At sea level it's a little over 16 inches. Very small cam for a 400, idles smooth, very docile. The engine has been perfect on 91 octane for a few years now. |
Good base line, note the ignition advance /rpm @ idle and compare after seating rings.
Good you made progress! ![]() |
Dennis I would try removing the vacuum advance and bringing up the initial to 18 or 20..... You will need a 160 thermostat to do this... I would try 89 gas too if your using 87..
The 2801 is an excellent cam for a powerful street Pontiac motor.. |
