Needs some work but a good looking car and nicely optioned, especially the 428...
https://www.ebay.com/itm/1967-Pontia...8AAOSwmt1gMQ9c
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming. 67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project. |
The Following User Says Thank You to Mark Simiele For This Useful Post: | ||
Maybe you should buy it as a donor car for your 67 Bonnie (or vice versa)...
Not an HO car.. and highly doubt its originally from CA.
![]() 1973 Formula SD455 - #'s auto orig paint 1972 Trans Am - 4 speed orig paint 1974 Formula 400 - Ram Air automatic 1966 2+2 convertible - 421 4bbl automatic 1967 Grand Prix - 4 speed orig paint 1967 GTO - 4 speed orig paint 35k orig miles |
My friend looked at it. Roof is rotted pretty bad. I don't believe it has HO manifolds. YH is an HO code for 67 from what I saw but I'll bet that it is a later engine.
From Wallace Racing: 428 376 HP WJ,XK,Y3,YH,YK
The difference between inlaws and outlaws? Outlaws are wanted |
It’s had a lot done to it , and needs a LOT more done do it!
If it was as nice as billed, it would be nice to have. It’s not, though!
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
YH isn't HO for a 67 428 376hp - it's the 360hp 428
Still a 4bolt Main Block with 670 Heads The PHS would have the EUN to prove whether it was the original block. Car isn't a California Car either - at least not as built/delivered. 67 Pontiacs sold new in California all had A.I.R. and their own separate Block Codes. 360hp Auto = Y2 376hp Auto = Y3 Doesn't completely mean it has never been to/in California though. I'm not 100% certain you could get Rally2 on a fullsize if it had Disc Brakes (from factory). I think you had to get the Disc Brake Hubcaps , which are Cool. It could be a beautiful car and looks to be drawing some bids. |
![]() Quote:
I had a '67 Bonneville that had the exact same rust in the back window and front window that was repaired and it was a NorCal farming community car all its life for 40+ years. That car was repaired before it did much of any damage to the trunk and it was gorgeous underneath and inside for sheet metal. The roof looks like it received a lot of paint from the factory despite the vinyl top, which likely saved the roof from worse rot. If you can fabricate the window channels for the rear window and patch metal, I'd say you would have a pretty nice car for not a lot of money. But if you're farming that out it's gonna be expensive if you can even find someone willing to do the work without a trowel. |
Could you even get 5x5 Rally II's in 1967? I thought they started later on full size cars when I looked into them for my 2+2, although I was using sketchy and likely incomplete web references to check. If they did have them in '67, do you (or anyone) know the 2 letter code to ID them?
The factory literature I have for 1967 specifically says you can only get 14" Rally IIs on big cars without disc brakes or H-70 wide oval tires. 1969's literature calls out that 15" Rally IIs for big cars are new for that year. I don't have definitive literature for big cars in 1968, but the language of 1969's catalogs indicates that it was "new" to get 15" 5 on 5 wheels then, so I presume that 1967 and 1968 you were not able to get disc brakes and Rally IIs from the factory (the "Disc" caps that came in 1967 were also no longer available then either). This is with the obvious caveat that factory pre-printed literature is not to be 100% trusted, but over these 3 years I think it's a pretty safe bet that factory 15" disc brake Rally II cars were not a thing until 1969 at the earliest (definitely by 1971).
![]() Quote:
![]() Quote:
I'm not sure about (i dont know) Cats, Bonn's, etc.. For the Stamped wheel code - i don't know - might can find it later. Photos courtesy of www.gt-37.org ![]() ![]() ![]() But on the 67 Fullsize Order Form i have (what PHS sends out) It does not list Rally2 or Hood Tach But both were available on 2+2 and GP So there must be another revised version of the 67 order sheet or separate sheet for GP and 2+2 , or maybe listed on the Special Equipment page. The 68 Order Form does list Rally2 and Hood Tach Also states Rally2 not available with #482 (15" wheel) or #521 (Disc Brakes) ![]() |
![]() Quote:
Stamp Code = JB GM Part # 9787860 |
![]() Quote:
My Apology The Automatics did not use a separate code - for whatever reason - idunno why. The Manuals DID use separate codes for AIR/Cali. Just witnessed a 67 GP 428 Sold New in Cali with AIR YH code on PHS 612 & 614 (616) Emission Codes on PHS , and AIR equipment still on the car. Zone/Dealer Code 24-100 in the LA district. State Codes = To:California (04) -//- From:Kansas (15) You can view the details/documents/car at this link : https://www.plainfieldpontiac.com/1967-grand-prix Still doesn't help build a case for the 4door Bonne being a Cali Car - no AIR pieces are present on the car. But it does open the door for higher "possibility" that it "could" have still been sold there - and all the emissions equipment removed. Y2 was Police Pkg 360hp Auto Y3 was Police Pkg 376hp Auto Anyone care to guess what would have made the Police Pkg a different Block Code ?? i will guess they used more Camshaft ? (068 Manual Camshaft) just guessing Quote:
Probably the Hood Tachs , also. Maybe they didn't make it to production - or were late - on GP & 2+2 Would need to find a PHS with #453 listed on it. None of the 67 2+2 PHS's in the new Registry have #453 listed Seems like at least 1 would so ................................... idunno The biggest oddity about the 67 Hood Tachs - they also are not listed on the 67 GTO Order Form either . Had never noticed this before. |
![]() Quote:
Or it was a car that got its engine rebuilt sometime in the last 50 years and they just did a Jasper-style core exchange or salvage yard take-out and replaced it with a generic other engine. No partial VINs in 1967 so without the P-O-P you'd never know besides seeing how close the date code are. |
The PHS will have the Engine Unit Number (number stamped by the Block Code)
As good or better than a VIN stamp - since most don't know about unique EUN codes to restamp them. Just as the PoP would have the EUN Anyone paying over 5-6k for the car should probably get a PHS on it. It's at $5400 now |
I messaged the seller and they said some online resource said YH was an HO. They now are aware it may not be.
Wallace Racing calls a YH an HO in 1967
Have a link?
I think I corrected that? ![]()
It looks like Ron Panzers car!!
------------------------------------------------------------ 1967 Bonneville Sport Coupe (Plum Mist), Org. paint, Org. 38K miles 1967 Bonneville Convertible (Montego Cream, Cal Car, 105K miles 1967 Executive Wagon (Plum Mist), Org. paint, Org 35K miles 1981 Bonneville Brougham Coupe (Black) Moonroof, Org. 11K miles |
