Intake gaskets
Wondering what guys are using that holds up really well for over sized intake gaskets?
Gasket I used are 1.20x2.40 on Edelbrock heads. I had a set of these gaskets split and cover the ports some. Thanks Link:https://tinindianperformance.com/pon...%20gaskets.htm
68 Firebird. IA2 block, 505 cu in, E-head, Solid roller 3650 weight. Reid TH400 4:11 gear. 29" slick. Best so far 10.12@133 mph. 1.43 60 ft. 76 Trans am, TKX .81 o/d, 3.73 Moser rearend, 468 with KRE D-ports, Doug headers, 3" Exh. Last edited by chuckies76ta; 10-09-2023 at 11:27 AM. |
My High ports were ported to that size but using those gaskets the bolt holes I had to redo to line up. Not on a motor yet.
SCE I think only has up to 2.350 tall.
Ill check them out. Thanks Skip
Tin Indian has a new performance gasket, vs the old school paper gaskets I previously purchased. Installed a set on my 325cfm heads- but only been a few weeks now. Material seems good to the eye.
Sent from my SM-G965U using Tapatalk
68 Firebird-- Street/Strip - 400/461 Eagle Forged Bottom End & Ross Flat top pistons. KRE 325 CFM D port, Ultradyne 263/271 @.050, .4267 lift. Crower Solid roller lifters and 1.65 stainless rockers. Quickfuel 1000 on Torker2 intake and 2" open spacer. Hedman 1.75" headers. TH400 w/brake. Ford 9" w/3.80 gears & 28x9 Hoosier pro bracket drag radial. Best ET: 1.35 60ft, 6.29 @ 107.20 mph, 9.99 @132.33 mph. 3,300 race weight |
The Following User Says Thank You to leeklm For This Useful Post: | ||
Thank you. I will check with them.
So I sent an email out to them and the new number is 1.20 x 2.40 Pontiac intake manifold gasket .060 thick D7900 That's the good part. Shipping came up as $230 U.S. I'll have to call em. Thanks Description 1.20 x 2.40 Pontiac intake manifold gasket .060 thick in our D7900 material which is more durable material that stands up better to alky and other more corrosive fuels. Gasket is used on the 325 cfm and 340 cfm KRE D port heads as well as a few of the standard pushrod location KRE High Port heads. Gaskets are sold in pairs.
Maybe that includes installation |
Fel Pro 1233
The Following 2 Users Say Thank You to Ken MacNicol For This Useful Post: | ||
The FelPro 1233 is only about 2.200" tall.
Unless changed the Tin Indian gaskets are a knock off of the SCE gaskets. Butler lists a 2.240" tall gasket: https://butlerperformance.com/i-2445...-128104-2.html Here is Summit: https://www.summitracing.com/parts/s...ntiac#overview .
'70 TA / 505 cid / same engine but revised ( previous best 10.63 at 127.05 ) Old information here: http://www.hotrod.com/articles/0712p...tiac-trans-am/ Sponsor of the world's fastest Pontiac powered Ford Fairmont (engine) 5.14 at 140 mph (1/8 mile) , true 10.5 tire, stock type suspension https://www.youtube.com/watch?v=qDoJnIP3HgE Last edited by Steve C.; 10-09-2023 at 05:43 PM. |
The Following User Says Thank You to Steve C. For This Useful Post: | ||
Intake gaskets have went to poop. Used to use SCE gaskets and could go two seasons testing manifolds more than a dozen times on the same pair of gaskets. Nowadays they don't seem to be oil, anti-freeze or crack resistant. If you're lucky a new set won't tear pulling the manifold off a never fired before engine. We've been using custom made Cometic manifold gaskets and so far no issues. We've only been using them for a couple of years so not a ton of feedback...... However all the gasket manufacturers got the memo to increase prices.
The Following 2 Users Say Thank You to PAUL K For This Useful Post: | ||
X2 .
Any part numbers for the Cometic .060 set. Thanks
Best bet would be to call them with your port dimensions and hopefully they have a match.
The Following User Says Thank You to PAUL K For This Useful Post: | ||
SCE can also make a .120 thick also. I have an intake that someone milled 0.060 too much just on one side! So different gaskets.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
We try to keep .030/.060/.090 and .120 thick in stock for that reason. It also helps to align the ports.
intake gasket
I had Flatout gaskets make me a custom set for my WP Eheads. I think it's .060 but it is a steel coated gasket. They went up in pricing as I bought a spare set. This reminds me of Felpro but fits a WP heads.
The Following User Says Thank You to 73 TRANSAM For This Useful Post: | ||
Are those doubled up or just single to do that? I used to have to run double, but ended up having a local guy make me some aluminum copies of the gasket and glued them to the intake. These are a 380 Highport gasket
Illinois Outlaw Gassers 6.27@107 9.97@131 |
The Following User Says Thank You to Bill Eveland For This Useful Post: | ||
Mine was just the single gasket .060 on each side. Not sure why it did that. I don't use any sealer on the gaskets. Did not have any vacuum leaks. Almost looks like an install issue on my part. I always trim the gaskets to get a perfect fit. I install a new set, we'll see how they last. But looking for a stronger gasket. Thanks for all who posted info.
I have good luck with the Butler gaskets. The ones from Tin Indian I had issues with them coming apart.
Come take a ride http://www.youtube.com/watch?v=P7Y8Awfk2I0 2008, 2013, 2015, 2016, 2019 Central Il Dragway Mod track champion and 2015 IHRA Div 5 Mod champion |
The Following User Says Thank You to Probird For This Useful Post: | ||
I had to use one 0.060" and one 0.120" gasket from Butler with my Victor/Dominator to get good port alignment. They only needed a small amount of trimming to fit well.
1967 Firechicken, 499", Edl heads, 262/266@0.050" duration and 0.627"/0.643 lift SR cam, 3.90 gear, 28" tire, 3550#. 10.01@134.3 mph with a 1.45 60'. Still WAY under the rollbar rule. |
The Following User Says Thank You to AG For This Useful Post: | ||
