Old 11-05-2023, 12:43 PM
Held for Ransom's Avatar
Default 1974 parts car
So, last fall I came across a '74 Firebird on the side of the road for sale. It had some parts on/in it with a card stating it had a 4.11:1 rear end. Another sign stated $2000. I drove off and a few weeks later it was gone. Earlier this fall it reappeared and after a month I finally saw signs of someone there and stopped. We struck a deal on a purchase price, figuring I will sell the rear to offset some of the cost of purchase. The intent was to save parts in case of an accident.
ID:	622817   Click image for larger version
ID:	622818   Click image for larger version
So long, farewell.
Old 11-05-2023, 12:58 PM
First up was the nose (header) piece. While it has a correct early casting number, it's been repaired and probably didn't originally come on this car.
ID:	622822   Click image for larger version
ID:	622823   Click image for larger version
ID:	622824   Click image for larger version
So long, farewell.
Old 11-05-2023, 01:10 PM
Next was the front bumper. This was an unexpected piece as it was not with the car when the deal was made. First thing I thought was strange was, the bumperettes were removable. While I had heard that '74s may have received this style, I had never seen it.
ID:	622826   Click image for larger version
ID:	622827   Click image for larger version
ID:	622828   Click image for larger version
ID:	622829   Click image for larger version
So long, farewell.
Old 11-05-2023, 01:18 PM
Unfortunately, all the lighting accessories (turn signal, tail light and license plate lighting) were "smoke" treated. Looking into what to use to undo this. The real bonus was the lower valance as it's the same for '74 or '75. Found 2 Power Beam bulbs inside. Will have to test.
ID:	622831   Click image for larger version
ID:	622832   Click image for larger version
So long, farewell.
Old 11-05-2023, 01:28 PM
New clue as to what was what, is the core support. Looks like the front end was from a '75. Soon will the interior dash as things aren't right there either.
ID:	622835   Click image for larger version
ID:	622836   Click image for larger version
ID:	622837   Click image for larger version
ID:	622838   Click image for larger version
So long, farewell.
Old 11-05-2023, 11:48 PM
Dang what has that thing been thru...good parts there tho
Old 11-12-2023, 08:20 PM
Car is a mess. Had a Chevy engine, which was why the previous owner purchased it. Most parts are OK replacement parts. Case in point is next.
Pulled the steering column as it was a tilt unit. Both levers were broken, but there are reproductions out there. Tried to figure out year and really can't. Why someone would take the ignition switch off a non-tilt column and make it work for a tilt is head shaking. Flasher knob looks like 1970.
ID:	623213   Click image for larger version
ID:	623214   Click image for larger version
ID:	623215   Click image for larger version
ID:	623216   Click image for larger version
So long, farewell.
Old 11-12-2023, 09:22 PM
Trevor78 Trevor78 is offline
is that a 1970 only style for the hazard?
Old 11-13-2023, 06:28 AM
I think '69 may have had the same knob. Earlier years, I think, were chrome. Dash pad and bezel look '70. Cluster was the original. Now I was thinking the 4.11:1 rear was a re-geared 10 bolt, but I'm now curious.
ID:	623240   Click image for larger version
ID:	623241   Click image for larger version
ID:	623242   Click image for larger version
ID:	623243   Click image for larger version
So long, farewell.
Old 11-13-2023, 06:05 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
Mike,
Does it have seat belts? I need a set of black shoulder belts for my '74 Formula.
Old 11-13-2023, 08:53 PM
Originally Posted by Rocky Rotella View Post
Mike,
Rocky, there was little interior. There may be a rear seat outer there, but then again...
So long, farewell.
Old 11-13-2023, 09:10 PM
Thanks. I figured as much but it's worth a try.
I'm looking for the shoulder belts (original owner cut mine) and a really nice woodgrain instrument panel with A/C and one accessory switch.
The Following User Says Thank You to Rocky Rotella For This Useful Post:
Old 04-30-2024, 10:24 AM
formula kid formula kid is offline
Do you have the full jack assembly?
Old 04-30-2024, 07:20 PM
I do for my other cars. But wasn't anything in this car.
So long, farewell.
