I bought one of those inside release/ locking hood latches for my '69 GTO as I don't like how anyone can open it from the outside, and I don't want to have to use a chain and padlock. The kit I bought was from the Parts Place, though this same kit seems to be sold from numerous vendors, and I'll describe below as well as on the included pics my process.
Overall- I was not impressed with the latch itself. It didn't match the shape of the original latch, it lacked the secondary safety latch, and overall felt thinner/ cheaper. Also, one of the latch fasteners was a bolt that would protrude up into the engine bay which would look bad, imo. I ended up cutting the locking portion of this and welded it to my original latch which solved all the above complaints, and I was able to retain the OG look while adding a modest sense of security to my car. I'm sure someone could overpower it if they pull hard enough or keep tugging. Hope I never have it tested.. At first I thought I would use this, and proceeded to remove the welded bolt and replaced it with a nutsert so I could re use the original fastener, and then gave the latch a coat of paint to help it look weathered like the rest of my car, but then decided to just add this locking part to my original latch. I cut it off and welded it onto my original, and then used a 3/16" rod to create the locking pin.
Long live the Muscle Car Instagram @tuske427 1967 Firebird #BVbird 1967 Firebird 400 4 speed project 1969 Verdoro green GTO (daily) |
I had to make more room underneath the core support and in the interest of time I quickly chopped the area larger. If I ever have the nose off I'll go back and clean it up more, but at least it's not something that anyone will see so I won't fret over it. I also made a clip out of a sheet metal clip nut to help secure the cable end onto the included end piece. It appeared to only press on, which was loose at best, and I wouldn't want this falling off while driving and then not be able to open the hood. Better to over engineer it now while I'm at home working on this. The addition of the lever housing underneath the dash was straight forward, and the unit has just enough cable to reach the front.
Once I reattached the latch to the core support the locking mechanism hit the top of the core support and wouldn't open. This was solved by adding a few washers between the latch mounting tabs and the core support. Other than making sure I put the latch back in the same spot no further tuning was needed. It works and now I can move onto the next project(s)
The Following User Says Thank You to Tuske427 For This Useful Post: | ||
Having some recent hood latch woes, I too came across that listing for the interior release.
I was curious how it was going to work, and a bit surprised to see how it all worked. I was thinking that it would have relied on the factory latch, and simply changed the pull rod for "something else" in the kit that I couldnt quite think of how it would work. How well does it work overall? Thanks for posting! |
![]() Quote:
Because I cut and welded the locking part to my OG latch I had to do a little fine tuning adjustments to get the lever to lock/ open like using the washers as spacers when I reinstalled my latch, open up the core support underside a little, and do a little filing to the mechanism to work with the 3/16" rod I welded in. Doing this extra work was worth it to retain the original latch with secondary safety catch.
Nice clean set up, you've got some strong fab skills! Two additional thoughts catch my imagination; first is if it would be better to hide the lock lever in the car, so as to avoid the temptation to break into the car? Second is I seem to recall a factory authorized (dealer install only) inside hood release only in those years. does anyone have an original or pictures of one? It the repop you bought based on that original setup?
My Break Away Squad 1969 Fbird (Base, 350, 400HO & Sprint Cvt’s - 400HO & TA Hardtops) 1969 LeMans (2dr & 4dr Hardtop and a Cvt) 1969 LeMans Safari 2 seat Wagon 1969 GTO (2 Cvt, 2 Hardtops & Judge Hardtop) 1969 Catalina (3 Cvt’s & a 2dr hardtop) 1969 Ventura 2 Seat Wagon 1969 Executive 4dr Sedan 1969 Bonnie Cvt 1969 Bonnie 3 Seat Wagon (2 of them) 1969 Bonnie Brougham (4dr Hardtop & Cvt) 1969 Grand Prix SJ (2 of them) 1969 2+2 2dr Hardtop (Canadian model) |
![]() Quote:
re: lock location. yeah, this could go further below the dash to make it even less obvious, or hidden, too, if desired. Of course, the cable is only so long so one might have to get a longer cable if locating it far away from the driver's reach. TBH it's not visible from the driver side of the car, and the average thug wouldn't know about this, either. As for a repop, I would guess yes, as it's being sold at pontiac specific places, and it has an era correct style to it. I too don't know for sure and would also love to see an original one to confirm either way.
Like so many parts you purchase today, they are cheaply overseas made. I used to chain my hood down underneath the hood but now only drive my car to shows and its kept inside. Still, even at shows I've had people touch parts underneath the hood which is quickly frowned upon when I see it....
I'm surprised that no one has simply reproduced the hood lock kit that GM used to sell;
They occasionally come up for sale, and when one came up for sale locally many moons ago, I went and grabbed it for myself.
You did a lot of impressive work on that Tuske427.
John, here is my interior hood release option. If I recall these were dealer installed from 69 to 72 on the A bodies. I'm sure you will know more than me about the years it was offered. I found this NOS example over 20 years ago. Its a nice option and while not a lock, its just like a modern car, pull to release on the interior and then pull the usual under the bumper for the secondary release. I found most people have never seen one and it does get some notice from the more sharp eyed show goers. Though it does require a note if the car is getting worked on as to inform its there and how to use it.
69 GTO convertible Warwick blue w/parchment, 400 4bbl auto trans, #'s matching, frame off resto w/ 36 options and more coming. 67 Bonneville 428 convertible one of one Verdoro green w/parchment, documented GM brass hat parade car with every option for 67, non running MAJOR future project. Last edited by Mark Simiele; 11-26-2023 at 06:04 PM. |
![]() Quote:
I bought one several years back but haven't installed.
Attached are scans of the paperwork that came with it. May help someone. Mike |
I'm curious if this was the same as the GM version?
If you had no release rod on the outside, and you popped the remote from inside, how would you release the safety latch when you got out to open the hood? Could this have been marketed more as a convenience than as a security feature? For example, if you drove into a gas station in 1970 that had an attendant, maybe this remote came in handy? OTOH, any service attendant would know how to open the hood... I know Oregon did not allow self-serve gas the last time I drove through it.. back in 1969 or 70 it was probably common everywhere. Mike |
This is turning into quite the thread!
Wow those docs came out great and makes a great comparison to the current market offerings. Thank you for sharing! |
Beginning back in the mid 80's, in boneyards, I occasionally stumbled across & pulled the accessory pkg "Hood Lock". They were installed on early 70's Oldsmobile Cutlasses, & remember right, a few Olds full size offerings as well. Pontiac offered basically the same black plastic pod, cable, & latch over the dealer counter as an accessory package. I've owned one of the Pontiac packages NOS, but after purchase & in examining the installation instructions, decided to not modify the 71's coresupport.
Back to the Olds installations, one thing I often ran across on the Olds installed packages was the chrome metalized lever on black plastic pod was often snapped off.
![]() Quote:
It worked this way on the aftermarket latch and same on mine. The difference is I welded a stronger rod to my latch lever than the one that came in the kit/ aftermarket unit, and my latch has the secondary catch. (it's also original so it looks better when the hood is up) the secondary catch is only for safety, it has no impact on the locking mechanism itself. hope this helps explain more
Interesting, it’s not in the 69 accessory brochure but the sketch of the dashboard is definitely 69. Maybe it was a mid year intro. It definitely wasn’t a factory option. I’ll have a look tomorrow in my November 69 MPC and see if it’s in the accessory section.
