Old 04-02-2024, 08:51 AM
64speed's Avatar
64speed 64speed is offline
Default Noise
I found a thread on here about undercoating and I have a questions. My car was not undercoated by the painter or AMD. Every rock or pothole or bad place for road noise I pass is just amplified by uncoated wheel wells and trunk floor. My question is do I want the coating to be like a rhino liner style product or something like regular rubberized undercoating. What are you guys using in these applications?
Old 04-02-2024, 09:53 AM
J.C.you's Avatar
J.C.you J.C.you is offline
I’ve been using the raptor bed liner underneath and a bubble wrap inside including behind the headliner. Makes for a nice quiet ride like a new car and not a tin can inside. Also glue the bubble wrap to the door and quarter skins so double insulated.
ID:	631482   Click image for larger version
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 04-02-2024, 10:53 PM
70GS455 70GS455 is offline
I also had Raptor liner installed underneath. Quiet plus protects from rock chips
Sent from my SM-S901U using Tapatalk
Old 04-02-2024, 11:00 PM
Road noise:
Under-inflated or worn tires.
Uhm, rear coils that lack the rubber isolation pads at EACH end.
A rattle with the package tray system, and the Deck Lid 2-ply glue spots.
The exhaust leaks.
Fix those and just. maybe you will hear a tiny rattle-squeak from the dash area flex.
Nowhere have i seen the need to add tar mats to reduce road noise. That should be a wow moment to others.
Sooo, after carefully building a solid body-mount moto- mount early bird, and a 68 GTO, i tink the lack of "deadener" can be achieved, yet include the raw engine and trans vibes, while being able to hear the stereo or passenger. Takes a bit of 3m glue to tack harnesses and such.
