1967 HO fuel filter CLOSE UP
Can anyone with a HO '67 give me a "Close Up" pic of the fuel filter/bracket at the front on the front of the intake.
Everything I've found online doesn't show a clear view. Thanks.
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
67 GTO Filter/Bracket
Jeff, not as close-up as I would like but this is all I can offer for now. It did not matter if Standard or HO as the 67's had the fuel filter secured with a right angle metal bracket that was held in place off the water outlet neck stud and nut. Many of these brackets were removed as they are extremely difficult to access for service. The filter would be secure without it because of the rigid fuel lines. The bracket is OEM correct and is nice to see on any correct 67!
Another Pic
Be aware that the early 67's (non-air, and air condition models) all had the "3 line" set-up with that small vapor return. Later 67's went to the single fuel line. Below is another pic showing the OEM installation from a forum member.
WOW, That's what I need, I take it the bracket is bolted to the water neck?
It that bracket avail in repo?
Here are a couple pics of mine, repro bracket and replacement filter that doesn't quite fit the bracket.
Both the bracket and the correct repop filter available. I have modified the fuel line from filter to carb on mine to fit the longer carb inlet I'm using.
"I fishtail through the lanes, and I make my tires squeal. Power at my feet, and glory at the wheel. I wind the windows down, let the wind blow through my hair. God knows where I'm goin' to, but me... I don't care." |
Old thread ... I know
does anyone have one of these original fuel filter brackets laying around I could buy . My original bracket is missing the round part so it must’ve broke some time ago Thanks guys gto19@att.net |
