Gasket kit
Where is the best place to find a full engine gasket kit and or gaskets?
Napa has some sets for the OHC
I have a few sets of NOS
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
The Felpro Full set is the ONLY set.
Runs about $130 and most auto parts will have to order it. Stay away from the ABC crap on EPAY
When I die, I want to go peacefully like my grandfather did, in his sleep. Not screaming like the passengers in his car. |
I may get ambitious and scan more of them so I can cut on my CAMM plotter.
If anyone wants a spare time project I need them saved in an AI or EPS format. There was a gasket manufacturer about a mile from me,that I took samples of to see about having made. They said fine if I wanted to buy 1000+ Victor is the only one that made the intake/exhaust that was worth a damn and those have dried up
Is there more to this opinion???
__________________________________________ "How I learned to stop worrying and love the OHC Pontiac L6" The Silver Buick- '77 Skylark coupe w/455, SPX, MegaSquirt 3 & TKO-600 (Drag Week 2011, 2012 & 2015!) 1969 Firebird with a turbo'd Pontiac L6 controlled by a MegaSquirt 3 and backed with a microsquirt controlled 4L60e and 4.56 gears! (Drag Week 2018!) |
Me too, Im looking at this set also.
I'm going to use it on my "throw together" engine, and so far from the looks of it, everything I need is there.
Thats not one of the ones I've seen, but they are priced matched to Felpro so I'll stick with FP.
I bought a set a few years back opened it up looked at it and then threw it in the trash. I'll see if I have the invoice, the set was a POS. If you are looking into BEST see if you can find a local dealer you may get a better price, they are not avail in stores.
I agree dont cheap out on gaskets
if you want to save money look elsewhere so you dont have to teardown a motor for a $.50 gasket that failed. Someone on the Cammer forum was having teflon cam cover and side drive gaskets made so they could be reused. Dont remember who it was tho,but they werent cheap
Everything comes and goes Pleasure moves on too early And trouble leaves too slow Last edited by Cammer-6; 01-29-2013 at 08:08 AM. |
Jeff and Cammer-6 are right on the money, don't go cheap on the gaskets. How frustrated are you going to be when a gasket fails and you have to tear your motor apart to replace a gasket.
Regarding the teflon gaskets, I have been told that when torqued the material tends to migrate resulting in loss of torque and possible leaks. I purchased a set for the accessory drive. They look nice, but I never used them.
John |
Well I guess I'll see how that E-bay set does. Looking over the individual pieces in the set nothing sets off any red flags with me. I'm not a pro-engine builder, but I've assembled a few engines and have used Fel-pro and non-Fel-pro stuff in my Buick's. One set of "some brand" head gaskets I got for the Buick I didn't really like the looks of, and eventually blew into the lifter valley, but I think there were other factors involved in that failure (racing, detonation, possible damage prior to installation..), but felpro's went back in. I'm not getting the same iffy feeling on this OHC head gasket as I did with the odd brand Buick one I used.
Big things are the head gasket and the cam housing gasket the cheap gasket sets don't always have the correct thicknesses
When you really do something right it's like you didn't do anything at all 1931 Pontiac 5 window coupe OHC6 powered 2015 GMC Yukon SLT |
I attempted to use the above mentioned Teflon and for me they just sucked.
I could not get them to completely seal and if I attempted to tighten to spec they would always squish and distort. Great idea just couldn’t make them work. I may still have one of the Cam House gaskets if anyone wants to try one.
perhaps a gasket coated with a material that will seal and also be non stick so as to reuse.
If I remember correctly the compressed gasket for cam cover is only .014-.018. Side drive isnt as critical on gasket thickness. The newer reusable gaskets have a metal core and are ribbed so as to seal in multiple areas. If a newer style gasket was made,simply mill some off the cover to compensate. Myself I dont see the need to remove the cam housing that many times, however moving the side drive for belt change is a nice idea.
Sure would like to fool some people with a OHC Pontiac, what bell housing do they have? Same as a Chevy 250 six?
Has anyone used the newer Felpro "Graphtite" or whatever it is head gasket? I have some older Felpro head gaskets AND three OEM steel head gaskets. I would like to use the newer ones if they are better.
69 OHC ZH Sprint Hurst 3 Speed 3:55 (1 of 213) 99 Valkyrie 1520cc Flat 6 108hp/110tq - For Sale http://sohcsix.yuku.com/forums/1/OHC-lounge Wanted: 1969 OHC "H" Camshaft |
