Old 01-28-2019, 01:27 PM
Stan65 Stan65 is offline
Default 71 seatbelt sleeves... soft or stiff????
All,
Does anyone know how stiff the front outside seat belt sleeves are supposed to be?
Not sure if they are supposed to be rigid, or be able to bend 90 degrees?
Stolen pic from giles http://forums.maxperformanceinc.com/...d.php?t=468849
Thanks,
Stan
Old 01-28-2019, 02:00 PM
RAIVJUMB's Avatar
RAIVJUMB RAIVJUMB is offline
Every set I have had have been fairly rigid. Not sure how they were when new though.
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
74 SD T/A Admiralty Blue Auto
others that reside in the barn too
Old 01-28-2019, 07:06 PM
455hota's Avatar
455hota 455hota is offline
Agreed. On my 71 they were fairly stiff, not very supple or pliable.
BTW I have a spare one left over from the restoration.
...Steve T.
"Resurrection of a 1970 Trans Am" Blog
www.455hota.wordpress.com
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Old 01-28-2019, 07:20 PM
455hota,
I have 2 of the same side that’s pictured unfortunately the other side I have is cracked a little on the buckle end. I would have been all over it if it would have been the other side.
Where does the small boot go? I don’t have those.
Thanks both of you for responding. Just trying to figure out if what I have is gonna work. Seems like it’s gonna be awful uncomfortable to have such a stiff belt.
Anyone have a picture with them buckled?
Stan
Old 01-28-2019, 09:54 PM
455hota's Avatar
The small boot goes on the end of the front inboard belts like in the pic below:
...Steve T.
Old 01-28-2019, 10:01 PM
Well, now I have to find a pair of them in black.
Old 01-28-2019, 11:26 PM
RAIVJUMB's Avatar
They are not all that bad actually I just worry I will brake them but I have not so far.
Sent from my E6782 using Tapatalk
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
Old 01-29-2019, 11:36 AM
RAIVJUMB's Avatar
I spent a lot of time on belts and gathering parts and partial sets and brought a couple of sets to get my car set up.
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
Old 01-29-2019, 04:32 PM
unruhjonny's Avatar
I have a pair of black front '71 belts... Mine too are stiff.
My guess is that they were much more pliable when new, and that they generally hardened with age.
At least I know I have the 'male' parts - they are siting in my office on top of a box with other belts... because they will not fit inside the box (without being bent of course).
1970 Formula 400
Old 01-29-2019, 05:40 PM
RAIVJUMB's Avatar
The small boot should be easy as they are the same or super similar to most of the other GM booties and black is popular, I believe A body is the same. Mark
69 GTOx2
69 Judge CR 4SPD
70 RAIV Auto Judge
71 GT-37:usa2
71 T/A WHT AUTO
71 T/A LB 4SPD
72 T/A WHT 4spd
Old 01-29-2019, 08:53 PM
dpoltzer's Avatar
dpoltzer dpoltzer is offline
I have a set on my 1971 and they are fairly stiff as well! If not going for the exact original look, can one just remove the plastic outer covers?
1970 T/A
Old 01-29-2019, 09:09 PM
Did these years always have the belt receiver on a stalk, rather than later years that used webbing but required the sleeve to keep in place?
Old 01-29-2019, 09:32 PM
The '70 1/2, 71, early 72 Birds with consoles had the lightly textured black plastic seatbelt buckle hanger that bolted through each side of the console. If no console was ordered the front female buckles typ were laying loose.
Mid '72 production F-body belts are where the fun begins... more changes. A relatively tall outoard retractor was used. Longer stiffer sleeves on the front female belts in an attempt to place the buckles further up and easy to access & not buried down between the console & lower seat cushion.
Old 01-30-2019, 01:03 PM
72projectbird's Avatar
Mine are somewhat stiff. They're not uncomfortable when wearing them.
1970 Trans Am RAIII 4 speed
1971 Trans Am 5.3 LM7
1977 Trans Am W72 Y82
1987 Grand National
