#41
Sure wish the edit time was longer. Anywho********
A set of 64 door handles 5719142 and 143 with factory gaskets (used). Probably fit 65 and others. Very minor wear on underside of handle pull. ZERO pits. Definitely won't be disappointed. $150.00 + shipping bill |
#42
Another offering.
6 chrome tops, 2 sets of bases for 64-65, 3 aftermarket screens, 1set of studs, and set of fuel fittings, set of wing nuts, and set of repro carb tags. I believe the lids and bases are OEM. I compared to my 64 and could tell no difference. Lids are very nice. Not perfect, but will not need restored. Bases will need painted. $200.00 for everything on table + shipping Thanks bill |
#43
I stumbled on a pair of anodized aluminum rear window belt line moldings for a hard top. OEM I believe in decent shape. No dings and not bent. Also 1 decent fuzzie, again OEM and 1 wiper, probably aftermarket. Anyone needs them, they are FREE, just pay the shipping, and that should be very minimal..
"Bill"! |
#44
Bill, I'll take the rear window belt molding if still available. I'm starting to put my 65 back together. let me know 60148 zip. Fill
#45
Pm sent
#46
Time to condense this list for Christmas. If you see something you need, make an offer. HO HO HO!!!!
Belt line moldings gone. All the tri power parts on table pending on USPS! A set of 64 door handles 5719142 and 143 with factory gaskets (used). Probably fit 65 and others. Very minor wear on underside of handle pull. ZERO pits. Definitely won't be disappointed. $150.00 + shipping Also for you A/C guys, I have a couple of the original air domes and fittings that attach to the fuel pump. A/C cars only. $25.00 ea. + shipping. Also am stumbling over a complete set of side glass for a 65. Most don't care, but a few are wanting original glass and they send to Florida to have restored. Just saying.. $150.00 + shipping Just stumbled across a nice 64 driver quality pair of original chrome valve covers with an ORIGINAL oil filler cap for a 64!!!! Dr. side has the hole for the rubber plug. PM for pictures. $150.00 + shipping. A pair of Dennis Kirban 64-65 splitters purchased in 1989. Used for 2000 miles and found NOS. Quality better than todays. Also have the hangers included. $225.00 + shipping Some parts for vacuum linkage 64 and 65 auto maybe. An original hose, Tee, and bracket the bolts to the pass. head, and the center carb vacuum switch. All in original condition. $50.00 + shipping. Set of 64-65 gray and black trunk mats; as new. Have ""part number and date code"" stamped on them. Plus 65-68 matching spare tire cover; as new. 64 does not use but will fit 64 tire. $80.00 + shipping 67 deluxe black seat belts. Very good driver condition. Plastic retractor covers are average; show some wear. Tag shows '67. $150.00 + shipping 64-65 transmission tunnel manual shifter porch. Still in the Ames box. Ordered and not needed. $25.00 + shipping 65 ram air pan. Is the one our host sells. Injected plastic. Hard to tell the diff. without a magnet!! As new with nice seal. $100.00 + shipping Heavy duty fan clutch. $35.00 9782482 water pump date code C084 cast impeller . Rebuilt by Arthur Gould $50.00 Coil 1115134 in good working order. Very restorable. $50.00 64-72 Idler arm for later model. Was on my 64 and removed. Not concours correct for 64-65. $25.00 Autometer 2 in. tach with column bracket. $30.00 Electric choke for a 65 for sure. Might fit others. Worked OK when removed. I put mine back to stock. $25.00 All items plus shipping. Need pics. Let me know. |
#47
ttt. Santa's sleigh getting full. Not much time left.....
#48
64 parts..
Bill, could you send me pics of these items,.. PM sent...
64' door handles, - chrome valve covers, and - 4 speed porch.. thanks jerrold,.. |
#49
Tri power parts on table sold..
THANKS PY forum... bill |
#50
Trunk mats sold
Shifter perch sold. Thanks PY forum Happy New Year to all.... "Bill"! |
#51
jspeed, PM sent....
"Bill"! |
#52
Still available.
"Bill"! |
#53
back on top. Make offers.
"Bill"! |
#54
TTT again..
#55
2 new additions:
539208 OEM fan- alt belt for a 64 GTO. Part number embossed on belt. I bought 30+ years ago as a spare. Never installed. Wonderful detail. $100.00 + the ride 542881 reproduction fan-alt belt for 65 GTO plus others. Part number embossed on belt. $25.00 + the ride. PM for more info or pictures. bill |
#56
Are the 64 valve covers still available?
37 Pontiac Sedan 455 700r4 94 Firehawk Supercharged 5.7 LT1 6spd. 77 Grand Prix base model, 350 pontiac 97 F250 7.3 turbo diesel 85 CJ7 Laredo 65 Impala SS 396, 4 spd, A/C. |
The Following User Says Thank You to moneypit For This Useful Post: | ||
#57
Yes they sure are.
bill |
#58
pm sent
#59
Valve covers and breather sold.
thanks PY!!!!! "Bill"! |
#60
ttt. It's summer for sure!!!
