Old 03-18-2024, 08:40 PM
bill ryder's Avatar
bill ryder bill ryder is offline
Default Need 4 spd info
Looking at 3, I believe to be, 64 Muncie 4 spds. One has no groove, one has one groove, and one has two grooves on the input shaft. Hopefully, someone can help me identify, or lead in a right direction!!!
THANKS
"Bill"!
Old 03-18-2024, 10:10 PM
tempest1964's Avatar
Bill, here is a link from 5speeds.com :https://www.5speeds.com/casting.html
Paul Cangualosi is very good on these. As he has stated in his book and his videos, due to the age of Muncie transmissions, sometimes it’s better to look at the casting numbers vs looking at input shafts due to previous rebuild and mixing/matching of parts. He has a lot of good informational videos on YouTube as well. Good luck
Old 03-18-2024, 10:50 PM
Seems like the 64 units had a smaller diameter countershaft - shaft hole bore is smaller in the front of the case.
Something about them is said to be slightly inferior , I think that was it .
Old 03-20-2024, 05:13 PM
Sunfirered64 Sunfirered64 is offline
The case should help with the year, the last three digits are as follows
1963 case number 704 corvettes only as far as I have seen
1963 and very early 64 had case number 606 very rare case used in corvettes, never seen in a GTO by me, but 64 corvettes got them
64 case number 325 with pat pending very early cars before Jan 64
64-65 case number 325 with pat number
66-67 case number 010
68-69 case number 660
70-74 case number 661
always pop covers as even replacement Muncie input gears had no grooves
Muncie close ratio heavy duty (m22) had no grooves on production line, but no heavy duty 63-65 m22 build (save for a very few rare road race corvette) many 63-65 have no grooves, this is why you have to pop side cover
Muncie close ratio (m21) had one groove
Muncie wide ratio (m20) had two grooves 66 and newer
M20 and M21 are not exclusive to the Muncie as this is the GM RPO code and Saginaw used this as well (Camaros and non SS Chevelles and other GM's that used both cases use The M20 wide ratio and M21 close ratio for Muncie and Saginaw cases)
The Following User Says Thank You to Sunfirered64 For This Useful Post:
Old 03-20-2024, 08:33 PM
60sstuff's Avatar
60sstuff 60sstuff is offline
Default Sunfire
Mr. Sunfirered64,
If you have a Sunfire Red ‘64, would you care to post some photos.
Thank you.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A).
2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option.
Old 03-20-2024, 09:36 PM
Rich-Tripower's Avatar
I'm not Sunfirered 64, but we have a Sunfire Red 64 and here are some pictures.
ID:	630741   Click image for larger version
ID:	630742   Click image for larger version
ID:	630743   Click image for larger version
ID:	630744   Click image for larger version
The Following 2 Users Say Thank You to Rich-Tripower For This Useful Post:
Old 03-20-2024, 09:39 PM
And just for fun, a few pictures from "back in the day" (early 1970s) and one of the alpha and the omega (we own both).
ID:	630746   Click image for larger version
ID:	630747   Click image for larger version
The Following User Says Thank You to Rich-Tripower For This Useful Post:
Old 04-05-2024, 04:08 PM
It is in my trailer and in project state as we we just moved a couple of months ago. The house we bought shop is very small, so we will be building a new building here shortly. Then I can start to work on it again.
Old 04-05-2024, 04:46 PM
george kujanski's Avatar
Chevy style muncies have the speedo fitting on the passenger side. Pontiacs have it on the driver side of the tailshaft housing.
Also the above comment was correct; the early units have a smaller countershaft; the later ones are 1" and better.
George
Old 04-08-2024, 05:14 PM
The speedo is mostly true, but the early ones all had the speedo on the drivers side up to the 010 trans 66 model year and then all had the passenger side once they went to the 661 case with the 26 spline input and 32 spline output.
Old 04-08-2024, 10:19 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Hope this helps. I didn't note the source
The Following User Says Thank You to GtoFM For This Useful Post:
