Old 04-18-2024, 01:45 PM
form74's Avatar
form74 form74 is offline
Default AC box removal
Can it be removed without taking off the Inner Fender.
I’ve removed them before but always had the car stripped to the fire wall
74 Formula
Below motor destroyed last fall
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
New motor
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Results will be posted after the track
The Following User Says Thank You to form74 For This Useful Post:
Old 04-19-2024, 02:20 PM
Mr. G Mr. G is offline
No. Must remove all bolts holding inner fender and at least move it some to gain access to the A/C box mounting stud s that are furthest to the outside.
Old 04-27-2024, 06:20 PM
GTOLou GTOLou is offline
When you do remove the suitcase off of the firewall. What do you guys do w/ the interior vents?
If you put standard/non-AC kickpanels - do they work? (the kickpanel w/ two pull handles for outside air)
Old 04-28-2024, 01:39 AM
Red80TA Red80TA is offline
Different topic, are you simply trying to convert an AC car to non-AC style? Many parts are specific, but you can swap kick panels with the pull cables and doors if you can get the full set up. Remove the cowl door or ignore, or leave hooked up with vacuum for recirculate if you keep the AC controls without the AC setup. Or keep existing kickpanels and ignore.
Old 04-28-2024, 08:54 PM
Yeah - want to swap an AC car to non-AC. Removing the box off the engine side firewall seems straightforward. You can buy a repro firewall fan/blower.
What else needs to be done when swapping the AC/non-vented kickpanels to non-AC vented kickpanels??
Old 04-28-2024, 09:20 PM
Have you looked at a heat only kick panel? Simply has a cable operated door to allow air or not. No need to remove the AC set-up to have no AC. Of course you my want to replace the AC case with a delete cover if cleaning up engine bay since different firewalls. Heater box under dash is also different but won't matter for this.
