What models have the same dash as the 66 2+2 catalina?
Wondering if 65's will work.Are they the same? |
I'm not sure about non-a/c cars, but my 66 a/c dash pad was not the same as 65.
the front lip is different. 65 is flat 66 is round. On the A/C cars the vent is in the middle for the 65 and on top for the 66. Other than that they are interchangeable.
patrick |
You can make them work, but they are not the same.
The difference between inlaws and outlaws? Outlaws are wanted |
I agree with SteveP. They are interchangeable. Since the Catalina pad only covers half of the top of the dash you should have no problem with fitting a 65 to 66 or vice versa.
If you have an A/C car then you need to use the a/c plenum that goes with that particular year. Jim
65 Catalina sedan. Allen Thomas Performance 495. KRE Heads at 310cfm ported by SD Performance, ProSystems Dominator carb on ported Victor intake, P-Dude custom grind hydraulic roller, MSD ignition, 3.50 Moser/Ford rear. F-Glass front bumper by son Rob, rear by the old man and joint effort for trunk lid. 3950# w/driver. Best of 9.5761/139 on 175 shot, 6.01 /114 in 1/8. |
Thanks guys!
So, there are no other models in 66 that are the same as the catalina/ventura/2+2. |
They are all the same for all models with the difference in appearance listed in previous posts.
When removing there is a screw the protrudes through the firewall by the wiper transmission. It can be a real pita if you do not know about this last nut. patrick Last edited by 65WJ; 02-26-2012 at 12:12 PM. Reason: added text |
Thanks for the info.
Thread Tools | |
Display Modes | |
