Old 02-06-2019, 11:20 AM
Default 1971 trans am fuel pump
Anyone out there know what part number ( Spectra or whatever is available that is correct )or where I can get a fuel pump for a 71 Trans Am thanks
Old 02-06-2019, 03:10 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
After nearly a decade of being unavailable it seems Spectra has started up production again of the correct '70-71 large can fuel pump. Part number SP1304MP.
Summit Racing and AutoZone show them as available. It also comes up as a product on the Spectra website.
Would have to give them a call to see if it's too good to be true.
Old 02-06-2019, 03:17 PM
Dens71TA's Avatar
O'reilly Auto has it under their Precision fuel pumps brand too. Looks like a reboxed Spectra judging from the pictures. Their price seems the cheapest at $22.99.
Old 02-06-2019, 04:07 PM
Norwood's Avatar
Norwood Norwood is offline
Sparks and I both ordered the spectra and it came as a small can. I have my doubts that they are producing a correct pump. But could be wrong. Lol
Old 02-06-2019, 05:05 PM
My Napa guy sent me the picture of the spectra pump and it was the small can
Old 02-06-2019, 05:39 PM
Dens71TA's Avatar
This is the picture that shows up for the Spectra SP1304MP. Napa doesn't carry this part number as of yet. They only have short can fuel pumps.
Old 02-06-2019, 05:45 PM
Judge273's Avatar
Judge273 Judge273 is offline
When I went to Oreilys to order the fuel pump for the 71 TA it came up on computer screen as the full body. I ordered it and it arrived as a short body.
The short body are available!
Mike/Illinois
Old 02-06-2019, 06:00 PM
Dens71TA's Avatar
Another case of a company with overseas manufacturing not knowing or caring about correct part to produce?
When the fuel pump died on my '71 T/A in early 2017, none of the parts houses even listed a mechanical pump as available. The only thing they had listed was a cheap retrofit electric pump. That is when I figured out that the 75-79 fuel pump was "close enough" to work.
Old 02-06-2019, 06:25 PM
I ordered one through Summit , This number is on backorder so it’ll take a couple weeks to find out if they are making them
Old 02-06-2019, 09:09 PM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
any reason this would not be correct for the '71 Firebird pump? It looks like the fuel lines aim in the correct direction compared to the one on my '72 but not sure if '71 is different. https://www.ebay.com/itm/40931-NOS-A...d9z:rk:37:pf:0
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
Old 02-06-2019, 09:11 PM
Norwood's Avatar
70-71 are all by themselves
Old 02-06-2019, 10:00 PM
The original from my 1971 Trans Am, and what I think is the Spectra.
The Following User Says Thank You to eaglesan13 For This Useful Post:
Old 02-06-2019, 10:03 PM
1971455HO's Avatar
1971455HO 1971455HO is offline
The pump to carb is close, but, the other two hose connections are 90* wrong.
Ol' man Smith
Pigeon Forge, Tn. Grand Rod Run Spring 2012
https://www.youtube.com/watch?v=DUIuGvWWthA
http://s223.photobucket.com/user/fas...d%20Run%202012
Son video'd this...
http://s223.photobucket.com/user/fas...a.mp4.html?o=0
Old 02-06-2019, 10:06 PM
I would have said none are close, and yet they still sell so not in their interests to bother correcting.
Old 02-07-2019, 12:00 AM
Formulabruce's Avatar
Buy this pump and the Ethanol will eat the crimp seat on the "Can" and will eventually spray. I give it 2 months . I have had 2 of the NOS pumps leak due to this. I did buy one off ebay ( aftermarket) that said it was Ethanol compliant. and has been fine for 2 years.
Old 02-07-2019, 07:23 AM
I can buy non ethanol gas locally. yes it costs more. . The fuel lines on the spectra pump I ordered from summit do look correct but it may not even be produced any more. Will have to wait and see
Old 02-07-2019, 12:10 PM
TA455HO's Avatar
TA455HO TA455HO is offline
I also can get non-ethanol gas so I'll just run this one. There are also additives that you can add to ethanol hosed gas to make it safer for older rubber.
6470499 3.900 All F/4 B.C PUMP (A.C. 40838) 1 1971 1971 3-11
Assembly number is 6440838
Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 02-07-2019, 02:39 PM
Chad
Yes looks like a good possibility nos maybe the only way to go
Old 02-07-2019, 06:54 PM
3tas4me's Avatar
3tas4me 3tas4me is offline
Does someone have a stash of NOS fuel pumps for cheap?
1970 Trans Am
1971 Trans Am
1974 Trans Am
1978 Y88 Trans Am W72/auto
1979 10th Anniversary Trans Am
1984 Trans Am
1993 Trans Am
1999 30th Anniversary Trans Am
2001 10th anniversary Firehawk #104
2006 GTO
Old 02-07-2019, 06:57 PM
I don’t but hopefully the spectra fuel pump comes in and it’s correct at least we’ll have something we can use and should be good for the ethanol fuel also . I heard we can send them out and get them rebuilt .
