#5381
if there aren't any hidden surprises that is the cheapest one ive seen in years.
#5382
keith k 70 Trans Am RA III / T400 / Lucerne Blue / Bright Blue 70 Trans Am RA III / M20 / Lucerne Blue / Sandalwood 70 Formula RA III / M21 / Lucerne Blue / Bright Blue |
#5383
Hi there have a cosmetical question for 1974 Trans am Super duty the Alternator with 80 amp the pulley and fan and nut must be silver plate or Black? thanks
#5384
Mine were not black.
Silver color on mine.
#5385
thanks for the answer also
Any pic of 80 amp Alternator? Thanks |
#5386
Here is one:
#5387
Are modified SD's allowed in this section? Starting build on a '73 with SD heads going on a 496. Otherwise, I'll post in the general area, if at all.
Thanks. |
#5388
With SD heads?
Sure! Did you buy just the heads? Know anything about the SD car or block ?
#5389
Don't know anything about the SD car or block. |
#5390
Original SD car ?
#5391
My car is an original D-port. Original engine is being put into storage.
#5392
Excellent Thanks for the pic just found the original Fan and Pulley Nos for 80amp Alternator and looks the same
#5393
Cool.
#5394
Hi can help me to identified this piece and where is install on 1974 Trans am SD455 Auto Thanks
#5395
Looks like one of those guards you install on the compressor to keep it from slinging oil all over the hood and fender.
1973 Formula 400 4 spd 04C build date Norwood assembly plant. |
#5396
thanks for help but i tried already and its not fit the A/C compressor the thing is when i bought the car came with 2 big boxes that everything i mean all the original parts replaced to the car is there and the only part a cant identified is this one may not belong to the car but 99% of the rest parts fit perfect. and also i never see this shield in any other year and i have long collection of this cars but..... thanks again
#5397
I would have guessed the belt guard too. That said, I have heard legend of oil drip shields for the motor mounts. I'm not sure if it was ever a thing for the SD's or if any members here have them. Here's the only pic I have. I'm not sure where it came from but possibly an old eBay auction. I only have the one pic of them too so I apologize for the angle.
#5398
Modified SD? Phhttt. Who would do such a thing?
12.84 @ 106.89 with street radials. 12.63 @ 108.39 on drag radials. |
#5399
Not today its all about duh $$$
#5400
1974 Trans am SD455 80amp Alternator & Starter Harness routing
Hi here is another question about the Harness that runs over the intake manifold on the driver side LH and going to the 80amp alternator and split and go to the starter
The question is the starter harness go in front on the engine and behind the Power steering pump and after go on the side of the engine thru the starter or the harness go inside the protector shield where runs the positive battery cable and runs under the engine please review pics i take this pic from another SD455 but dont know is correct non AIM or Shop manual show correct routing for starter harness with 80amp Alternator thanks again |
Thread Tools | |
Display Modes | |
