Thermostatic control for a 'Dorman' electric fan ?
Hey guys,
I'd like to install a thermostatic control in my 65' GTO electric fan. I figured it was a good idea, like after the car is turned off, the fan would continue to run, like on newer cars ? Questions: 1) Do I need a thermostatic control at all ? 2) Do I also use the OEM fan (actual fan blades), or just not install the OEM fan at all ? Or won't there be enough room for both ? My guess is the actual OEM fan would mess up the control's temperature sensing ? 3) The electric fan is a Dorman unit # 620-634 from RockAuto.com 4) The car has a brand new OEM 4 core Harrison 5) The car has a Vintage Air system installed, so no more factory heater core Any tips or tricks you could throw my way are super appreciated ! Dave dlarkins@comcast.net 610-842-7905
'65 GTO Hardtop 389 .030 400ci Tri Power, .068 cam, HO manifolds, M-20 4 SPD, '70 12 Bolt 3:36 Chevrolet posi-traction, Montero Red, Parchment gut, VINTAGE AIR, PFDB, Bilsteins, F&R HD Sways, Hotchkis rear bags, Firestone Indy 500 shoes "What's the point of owning a muscle car if you can't scare yourself stupid from time to time ?" |
I used a Taurus 2 speed fan. I created my own thermal control circuit with 2 temp switches in the heads and some relays (5 in all). Slow speed comes on at 185, Hi speed comes on at 200. I also have a manual override switch to kick it instantly to high speed. And it will also be enabled by the a/c compressor kicking on.
But all of these functions can be provided by some ready-made fan control circuits, with some being very simple for a single speed on/off at a specific temp setting, and others for dual fans and other features. I ended up spending about as much on components and wiring as purchasing a unit would've cost me. I doubt you would be able to use your mechanical fan with the electric if your electric is a puller. If your fan is a pusher, you could probably do both. Something like this is simple and to the point: http://www.buyautotruckaccessories.c...FSoZQgodSQnAVw Google "electric fan controller" and you find quite a few out there. Just be sure to search for some reviews and opinions, because I've read a number of complaints about durability from certain manufacturers.
"...ridge reamer and ring compressor? Do they have tools like that?" |
Which one to buy then ?
Do I buy the $50 one OR the $250 one, for a nice street able show car ? GTO
Decided on this one
Now THAT looks nice! I'm curious what your review will be on ease of install, durability, etc.
And the price looks nice for the additional features!
Check out DERALE products...I used thier shroud with dual fans, and the relay/ temp switch they make for it.....nice products, and support. Eric
PM Sent
1969 428 Tremec 5 Speed U.S. Army Retired Retired Helicopter Pilot |
Here is a pic
You wouldn't happen to have a picture of the side where it attaches do you? I am still trying to decide if I want to buy these for my car but I want to make sure I can mount them without a lot of modification.
Thanks, Dale
If you send me an e-mail address, I can get you a few pics...
HERE are a few pics....hard to see, but it is a 'crowded area"....
DC Control is a one-man show, Brian Baskin. He's an electrical engineer, and builds these himself. He has test cycle (2 days long, I believe) that he puts EVERY controller through, before he ships. I've lost track of how many I've installed and convinced others to buy, but I've not seen any that failed. I have one that is 12 or 13 years old and still working fine. It usually takes a few weeks to get these, but IMHO well worth the wait.
http://www.dccontrol.com/constant_te...ontrollers.htm
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Dale
Thread Tools | |
Display Modes | |
