Old 11-04-2022, 10:33 PM
Zooguy Zooguy is offline
Default Disc brake upgrade big body
I have a 1966 Pontiac Star Chief executive and I'm wanting to upgrade to disc brakes in the front. I didn't know if there was a front spindle from a tempest GTO or firebird that would allow me to use disc brakes from those vehicles. I'm not worried about the bolt pattern changing because I'm buying different wheels for the car. If it's possible I would rather figure out a way to use just off the shelf stock parts from other vehicles instead of custom aftermarket stuff.
Old 11-04-2022, 10:55 PM
gtokid1968's Avatar
gtokid1968 gtokid1968 is offline
scarbird https://scarebird.com/
makes kits for most cars
Old 11-05-2022, 12:29 AM
Schurkey Schurkey is offline
I'd be looking for a '69--70 full-size Pontiac, perhaps any GM B- or C-body of those years, that has disc brakes in front.
The '67 and '68 discs would be the four-piston, fixed caliper version that's hard to get parts for. '69-newer would have the good ol' single-piston floating-caliper stuff that's cheap and abundant.
The '66 would likely still be the hateful single-circuit master cylinder. You'd want to upgrade that to a two-circuit master with a combination valve to split the front brakes from the rears.
Old 11-05-2022, 10:50 AM
Yes my master cylinder is a single well and to me that's terrifying cuz if it has any failure or problem I lose all four brakes having a dual well master cylinder gives a little bit more piece of mind. So I need to be looking for a 1969 or 1970 big body Pontiac with the floating front calipers. Hey if I found one would the spindles be an easy direct swap over? And would the brake booster for the master cylinder bolt to my firewall?
Old 11-05-2022, 12:19 PM
Stuart's Avatar
Stuart Stuart is offline
Scarebird is unfortunately closing up shop. Ames lists a disk brake kit in their catalog. https://secure.amesperf.com/qilan/De...A&web_access=Y
The Following User Says Thank You to Stuart For This Useful Post:
Old 11-05-2022, 12:49 PM
I don't know about Pontiac. My guess is that it's the same as Chevy. Maybe even the same pieces--corporate B-body might be all the same.
With Chevy B-body, the knuckles, calipers, hoses, rotors swap directly back to '65. The wheels need to be different because the disc-brake wheels have more caliper clearance than the drum-brake wheels. The master cylinder and booster should swap directly over. I don't know what control valving there is--might be separate pieces rather than a combo valve.
The A-body needs "special" lower ball joints, but I don't think the B-body does.
Mind you, I've never done a B-body disc swap. Maybe you shouldn't listen to me.
Old 11-05-2022, 02:40 PM
SRR's Avatar
SRR SRR is offline
http://www.slyagent.com/67cat/dsc01.htm
Ben M. and I did this on a 67 Wagon a few years back. Is your car A US or Canadian model?
― Calvin Coolidge
Old 11-05-2022, 03:20 PM
HoovDaddy's Avatar
HoovDaddy HoovDaddy is offline
Full size Chevy's have a 4 3/4 bolt pattern, POB and Cadillac are 5".
https://forums.maxperformanceinc.com/forums/attachment.php?attachmentid=585876&stc=1&d=1646964  761[SIGPIC]
The Following User Says Thank You to HoovDaddy For This Useful Post:
Old 11-05-2022, 09:52 PM
242177P's Avatar
242177P 242177P is offline
Yeah, I've got another donor I could suggest, but when someone that's back-halfing a car, and switching to a 454 with a blower balks at fabricated caliper brackets... well, they're just impossible to please.
So with that in mind, graft a Mustang II front clip onto it. You can get around the 4bolt wheel pattern by using rims from a one ton pickup, because 8bolt.
Old 11-05-2022, 11:52 PM
Ita a US car
Old 11-06-2022, 12:03 AM
Please forgive me if i portrayed the wrong intention. I am NOT BALKING any options at this time. I am just trying to learn as much as i can and discover ALL my options and figure out the best choice. I do like the brackets that have been mentioned but im trying to figure out how to get disks and a smaller bolt pattern for the wheels want to put on the car.
Old 11-06-2022, 12:12 AM
Stuart's Avatar
Pontiac suspensions were totally different than Chevys until 1971, when GM went with a more corporate chassis design for full size cars.
Old 11-06-2022, 12:23 AM
mrmark1957 mrmark1957 is offline
I did a 4 wheel drum to disk, manual to power, conversion for a friend on his 66 Impala about 20 years ago. It was a complete kit. All went well, pedal and stopping power felt good , he drove it for all these years, never complained, just sold the car recently. I dont remember the company that made it though.
Old 11-06-2022, 12:06 PM
pfilean's Avatar
pfilean pfilean is offline
It gets confusing learning what interchanges. A body, B body what year did this or that change and when may A or B body use the same.
I have a 61 Ventura (OK, call it a B body). I have C3 Corvette (that's like 68-82 years) brakes front and rear including dual MC. It uses a Corvette spindle (yes, the ball joint taper seems to be the same) with the Pontiac A arms. That spindle allows using the Corvette Moraine calipers. Although the brackets need to be modified to move the caliper behind the spindle not in front as Corvette did it. Rear is Corvette although the axels were redrilled to 5 on 4 3/4. Took some ingenuity to get the parking brakes to work.
Can't say what the cost would be compared to a Scarebird system. Probably cost more and if I hadn't gotten this system when I bought the car, I would likely do a Scarebird system if it is available. But the nice thing about the Corvette system is that I expect parts will always be available and I know what they are.
The Following User Says Thank You to pfilean For This Useful Post:
Old 11-06-2022, 12:46 PM
We may have a couple of sets we can make from extra components.
Rotor pattern is 5 on 5. If you wish otherwise you will need to redrill, spotface and trim pilot down from 3.06 to 2.780.
Old 11-06-2022, 04:15 PM
Yes I am trying to figure out a way I can use your kit but get a 5x4¾ bolt pattern.
I'm not sure what you mean by spot face and trim pilot down from 3.06 to 2.708
Old 11-07-2022, 10:03 AM
rustyrelic rustyrelic is offline
If you were willing to stick with 5x5, I would definitely go with the 69/70 front spindles. The rotors are a little tough to get but still out there if you beat the bushes. I dont believe the later year pontiac stuff with work as it is a question of front steer vs. rear steer so nothing will line up. Don't believe any chev stuff will work either. Maybe redrill the 69/70 rotors?
The Following User Says Thank You to rustyrelic For This Useful Post:
Old 11-26-2022, 09:00 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
Default Disc Brakes
I have some knuckles I just pulled from a 69! I doubt rotors will make spec. Jim
Old 11-26-2022, 09:42 PM
Knuckles are the scarce and important parts. Ball joints, calipers, bearings, rotors, hoses, tie rod ends...all of that can be had at the local parts store, or Amazon, or a dozen other on-line specialty shops.
But if you don't have knuckles that will work, it ain't happenin'
Old 11-26-2022, 10:10 PM
'69-70 B series Pontiac rotors were reproduced near a dozen years ago, but are not a local parts store item, have to order them from the importer/his downline. California Pontiac Rescue had them a while back.
