Power Window Switch on 1980
Does it matter which way it's installed? Is there a top or bottom? I didn't pay attention when I took it out. Fits either way.
I'm not positive, but if the wires connect either side, that would determine the 'Up' or 'down'? One wire is probably down and one is up.
Thank you. I checked it w/ a meter. All it does is hook onto the wire connector. The switches seem to connect the same terminals. Just verifying. Don't want to pop a fuse or CB.
Plug only goes on one way as there is a locating prong to make it only go one way.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
Thread Tools | |
Display Modes | |
