Silly me, I was going to have the spring seats machined. I took my heads to my machinist to have them machined and walked out with a set of +.050 valve locks. I'll put them on the exhaust valves only.
Tim Corcoran |
those usually work just double check rocker still contacts valve tip seem retainers it moves up too much.
The Following User Says Thank You to Skip Fix For This Useful Post: | ||
I would say that only the designer of the cam profiles can correctly answer the spring force [not "pressure"} questions. Values such as peak negative acceleration aren't usually available to end users.
Anybody else on this planet campaign a M/T hemi Pontiac for eleven seasons? ... or has built a record breaking DOHC hemi four cylinder Pontiac? ... or has driven a couple laps of Nuerburgring with Tri-Power Pontiac power?(back in 1967) |
The designer of the cam is gone now but, Bullet knows Ultraydyne cams as well an anybody . Tim at Bullet worked for Harold for several years. Bullet highly recommended to run 1.65 and they recommended the springs too.
Tim Corcoran |
Yeah I already check the clearance and it's good. My machinist made the same recommendation. Thanks
Tim Corcoran |
Thread Tools | |
Display Modes | |
