Old 04-03-2024, 10:17 PM
Tim Corcoran's Avatar
Silly me, I was going to have the spring seats machined. I took my heads to my machinist to have them machined and walked out with a set of +.050 valve locks. I'll put them on the exhaust valves only.
Tim Corcoran
Old 04-03-2024, 10:39 PM
those usually work just double check rocker still contacts valve tip seem retainers it moves up too much.
Old 04-04-2024, 12:39 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
... There’s only one way to correctly answer that...
I would say that only the designer of the cam profiles can correctly answer the spring force [not "pressure"} questions. Values such as peak negative acceleration aren't usually available to end users.
Old 04-04-2024, 09:48 PM
The designer of the cam is gone now but, Bullet knows Ultraydyne cams as well an anybody . Tim at Bullet worked for Harold for several years. Bullet highly recommended to run 1.65 and they recommended the springs too.
Tim Corcoran
Old 04-04-2024, 10:23 PM
Yeah I already check the clearance and it's good. My machinist made the same recommendation. Thanks
Tim Corcoran
