Gto splash shields
I need a pair of 1964 gto front splash shields, anybody have a set for sale, non air
I definitely have one, but might have a pair. I thought they all had the holes for the a/c baffling even if not used for ac. You can email me at arayman@aol.com
Have a set of 2 for the fender to core area PM sent
Just out of curiosity, can someone provide pictures on the car? I can't picture what is being discussed.
TIA
The '64 GTO The '65 Chevelle The '69 Chevy Pickup Project The Brazen Orange 2006 GTO |
The Following User Says Thank You to Rich-Tripower For This Useful Post: | ||
Splash shield pics.
The Following User Says Thank You to GtoFM For This Useful Post: | ||
64 gto front splash shields avail & A/C long lowers
Is the shield different if the car has A/C or is something added?
Can’t answer your question directly, however my 69 MPC shows two different shields for the 64.
One for the T/6-T/8 with AC and TI. I’m guessing TI is transistor ignition which need to be shielded? The other is for T/6-T8 except TI- makes no mention of AC. My 74 MPC shows no listing so discontinued by that time. The pictures are the splash shields from my 64 GTO- NON-AIR. The car was all original when I purchased it in 69 so I know these are correct for non-air application. |
The Following User Says Thank You to 64-3Deuces For This Useful Post: | ||
Here are a pair of 1964 slash shields. One has a factory A/C sheet metal baffle installed on the bottom, clearly both A/C and non-A/C applications used the same splash shield.
The 1964 A/C baffle has a narrow extension that wasn’t used for 1965 as you can see in the last 2 photos (‘65 baffle at the bottom). The drivers side 1964 baffle is an original, the passenger side baffle was fabricated for me by my brother, they’re not easy to come by. Right now in the process of restoring the factory A/C on my Le Mans convertible.
The Following User Says Thank You to b-man For This Useful Post: | ||
b-man,
Good info, the difference for the AC being the added shield; never seen one. Do you have any idea why the MPC shows used also on TI as noted in my post #10???? |
I have no idea in the TI ignition.
Just sharing some parts I’ve accumulated for my long-term project.
Thanks again b-man! So the staples on the added baffle are for the A/C seal kit filler piece?
Indeed they are.
TI had a cutout for the cover - amplifier box.
Thread Tools | |
Display Modes | |
