Old 04-30-2024, 05:11 PM
form74's Avatar
form74 form74 is offline
Default Front Subframe between motor mounts looks Damaged
Just pressure washed the engine bay and subframe , is this normal or did my 455 motor explosions cause these holes, to me they look like part of a rod hole.
I also included the shot of what the oil pan look like
ID:	632945   Click image for larger version
ID:	632946   Click image for larger version
74 Formula
Below motor destroyed last fall
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.061 @ 110.74
12.092 @ 112.43
12.128 @ 111.71
New motor
461 stroker
Edelbrock 87 cc dport heads
Performer RPM
Results will be posted after the track
Old 04-30-2024, 05:45 PM
WOW!
I would say it is from the engine. That is some pretty thick metal there, must have been running for awhile chopping at it?!!
Old 04-30-2024, 05:59 PM
WOW, have only seem damage like that once before to the crossmember of a subframe.
Have pulled countless subframes from partscars & projects & waaaay too many engines.
As ragged as the edge looks where the rods tore out that "slot", I'd use a cutoff wheel & clean up the edges of that slot. Then, carefully reach up in there & feel around the backside for any deep rust pocks. If no internal rust damage, trim a piece of steel plate & weld it in.
