![]() Quote:
Lynn McCarty dba/McCarty Racing www.RamAirV.com lmc3470@aol.com www.ChemicalManagementIndiana.com 317-260-3486 |
![]() Quote:
We have Tri-y headers mfg in Indy, but I just sent them off with Calvin for a customer. As soon as he makes sure of the proper fit we will be going forward. Guys this engine as tons of torque. We had hoped to pull it from 3000 RPM and up, but it just wasnt in the cards.
1/4" up will fit fine (at least on my car). The T1 intake moved the carb up and back more than that and it still fit, so sounds good. I will be watching this closely, do you plan to do any testing on 4" or 3.75" stroke engines?
The crashes people remember, but drivers remember the near misses. |
I have a (433) with a 4" scat if Lynn wants to send me a set to test
![]() Rather than see how high this engine can be pushed I'd like to see how low it can be brought down and maintain some street manners. If the intent is to offer a true street version it needs to idle and have low rpm throttle response. Granted it'll need to wind up to make peak power but on the street low to mid range is where it'll be most of the time. A test stand would do, doesn't have to be on a dyno to see how it works on the low end. |
"People would be amazed if they new the whole story with valve springs and a Pontiac."
As we discussed, I wasn't surprised at all. Been on the dyno a few times and have looked right at the charts and have seen what can happen when your springs aren't up to the task! Certainly new territory you're into here. Makes the shorter stroke packages look real appealing as well.....Cliff
With that short of a stroke that is going to be a high reving engine. I think we were over 630 foot lbs of torque on this street engine and it averaged 600 ft-lbs over a very long band width. This was with a 2 inch tube and a 3 1/2 collector. This amazed me. I am so very interested to see how we can tune a cam and incorporate the tri-y headers. The tri-y's have the firing order cam to match the sequencing of the header tube location to promote pulse tuning. I am so interested to see who this works with our stuff.
![]() Quote:
Since the only jigs that were free in the last few weeks was the V jigs. He did all the SS building processes & cost evaluation using the V pattern. He built only one side & turned out nice for the first SS piece. He is happy with the way it turned out & set it aside. There wont be a mate to that header for at least a month or more. Like I mentioned it wasn't on the agenda & was used for testing the build process.
Deanna ![]() |
![]() Quote:
My application is geared toward road racing as well (I am a pro-touring guy). My car isn't actually a race car but I plan to build it strong enough to survive say a track day or HDPE event type run. I also plan on running a steel 400 style hood on my 67 as well as the 67-68 ram air pans, so hood clearance is also an issue for me. Where I gain room is that I am using fuel injection and the TB is shorter than a carb. The reason I asked on the tri-y is I need the ground clearance. Lynn if you can PM me who is building your headers in Indy?
Ben Mowery |
No problem publishing this. Here is his website:
www.theindycartel.com Joe is a fabulous fabricator. He has a shop in Brownsburg where John Force, Impact Racing, Vance and Hines, and all the racing shops are. We are considering putting a shop in that area, you can get anything done for anything race car or street car on that block.
We have tri-y headers that we didnt have time to test as the RAV kept breaking the dyno, lol.
Just a side note, can the guy who rated this thread one star have the courage to reveal what he didnt like about this particular thread? I didnt see anything negative about what was posted...unless you just dont like Pontiac Power? I love it all and I support all the people who do it. It keeps Pontiac alive whereby if it weren't for everyone's effort, it would surely die.
It was rated "one star" Lynn because I started it and some like to get their licks in whenever they can. I rated it 5 stars. Thanks for your efforts in this project.
Tom Vaught
Thread Tools | |
Display Modes | |
