Non Pontiac Motors in Pontiacs includes factory 403,305,350 Chevy, Buick V6, Also Pontiac Motors in non-Pontiacs! |
Whatever. Thanks for the advice.
Tom V
Jim By the way, X3 on this topic being posted in the wrong place.
****'63 Tempest, 475" IAII, Wenzler Super Chief heads, converted to blown alcohol, Birdcatcher, Littlefield 10-71 high helix. Best pass to date: 7.67 @ 181.59 (1/4 mi.), 4.95 @ 143.67 (1/8 mi.), 1.18 (60 ft) 7.75 @ 178 pass: https://www.youtube.com/watch?v=Iez3...ature=youtu.be First seven second pass(7.98): https://wwwoutube.com/watch?v=DK17...ature=youtu.be Thanks to Paul Carter @ Koerner Racing Engines |
Are you going to take away my birthday for posting in the wrong place on accident? I seem to remember people being helpful and nice here. I've been a member on this board for quite some time and don't remember so much animosity.
It gets that way.
I got my TA back from paint jail - 6.2 LS3 EROD with TKO600. I may never go back to traditional anything again (especially after all the ****ery I dealt with concerning hydraulic roller lifters) |
All I said that it needs to be put on the non Pontiac motors in Pontiacs thread they talk about turbos there too with there non Pontiac motors I'm a purist and I think that the motor is the heart of the beast Pontiac in a Pontiac and Chevy in a Chevy I'm just old school sorry Tom LOL
GTO George Last edited by GTOGEORGE; 02-17-2015 at 04:29 PM. |
It has GTO coil covers now.
Keen to follow this project as I'm looking to build a turbo LS set-up for my '64 Bonneville (far easier to get Down Under than Pontiac speed stuff)
Cool build...in all honesty an LS is a corporate GM motor. Its not a SBC/BBC and absolutely nothing is interchangeable between the 2. I am a Pontiac purist but putting an LS into your GTO to me is putting something corporate between the frame rails...not a chebby in a Pontiac. That motor has been between many G8s, GTO's...does that make it a chebby. NO Im considering doing the same thing in my Lemans just because of cost.
68 Firebird "Indian Giver" 540 MR1, HP's, Wenzler -- For Sale $12,500 rolling Best of 5.12@134 on 175 shot 72 LeMans "POS" - Next US beast |
Ls1 are very nice engines, but they do cost money to adapt to older models..what matters is that you are happy at the end. good luck..
It would be one thing, if that specific sub-forum was having multiple new classical-Pontiac specific posts per day, and a thread like this was bumping some of those to page 2. But the reality is that that there are page 1 threads which have not had a comment in over 2 months. If anything, this thread gave a slight boost in traffic to a rather ignored sub-forum. It was quite petty, IMHO, to have this thread moved.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
Way petty.
On another note I did build a cool little surge tank that I mounted under the hood instead of one of those ugly monstrosities I see in people's trunk. I took a piece of 5" truck exhaust pipe and built a top for it out of 5/8" steel plate that was tapped to 1/4" npt and for the pressure port was tapped to 1/4 npt on both sides for a fitting. I welded it in and installed the inside piping and high pressure fuel pump. Then I welded on a 3/16" thick bottom plate while cooling the whole deal with water. It holds about two liters and the pump inside is a 350 Lph pump so it can support a ton of horsepower. The lift pump sending fuel to it is a carter something or another and has a strainer before and 10 micron filter afterward. It should keep me from having fuel starvation issues because of the no sump tank. Turbo engines don't like that at all.
It's the first picture in this gallery. Let me know if the gallery link works.
http://forums.maxperformanceinc.com/...p?albumid=1538 |
Three ports are the supply from tank, return to tank, return from fuel rail, and the plumbed one is the pressure to the fuel rail.
Was there any hood clearance issues with the truck intake?
#38
Not the intake. The alternator was a large case alternator and it hit pretty bad. I went to a 105 amp one and used an air hammer on the hood bracing to get it to clear.
#39
does anyone make motor mount adapter for modern LS engine to 70 lemans frame or did you have to make it? thanks
#40
What happened to the first photo in the thread?
Thread Tools | |
Display Modes | |
