#41
Actually it very well could be.
I have a very good experience lately with webcam ( http://webcamshafts.com/ ) It might not hurt to give them a call...
#42
Thank you all for your replies. I'll figure out something when I get back onto the project. I was just curious what options were available and if I had missed an outcome to this thread.
2-1962 Lemans convertibles 4cyl, auto 1962 Tempest safari wagon (running project) 1972 455 Formula (tribute) 1962 Skylark convertible 215 4-barrel , auto 2009 G8 Sport red metallic, Onyx leather Whatever else that make my way into the driveway |
#43
Well, its been several months since this topic was last replied on. Has there been any increased interest or info or progess on replacement cams?
#44
The interest is there, the problem is finding a company to invest in the manuacturing of the cam. Another problem is they need the core to custom grind the cam. These cam companies are not producing these cores. Some have a few cores laying around and will grind one down for $400. Seems pretty steep since V8 cams are less than half that price. Two companies that will work with us are Nunzi and Butler, but expect to pay a hefty price to them for it.
I spoke to Isky who used to manufacture cams for the 4 banger back in the 80's and he wasn't able to help either. I spoke with the guys at Butler Performance when I was in Norwalk last summer and they seem interested in working with us. We should find out how many are still interested and get Butler a count so they can price it out. How many will want a stock 4 barrel cam and how many will want a high performance cam. Then we would have to define the high in performance too. While we are at it, see if we can get them to produce an aluminum intake too. I thought about contacting Edlebrock since they like to produce the entire product from the heads up. First we need to get a count of who wants what. |
#45
Thanks! Randy |
#46
Would you have to get some rods and cut them down? |
#47
just bite the bullet and do a roller cam.No problem with cams then.BOP and Comp have blank billets.Not cheap but you can geterdone.Tom
#48
Bore .060" put a std 400 Pont Probe forged flat top on a half set of Tomahawk rods ,rebalance stock crank and get a single 65cc HRE head (10.5:1)and a 4 banger version of "Ole Faithful" 236/242 112 Hyd Roller , Harland Sharp 1.65's and a ceramic coated Hooker Super Comp header and a welded up Torker II intake with a 390 Holley ..LOL Sum Beech
63 Catalina coupe 467 cid budget drag car 11's 1/4 , 7.20 1/8th pump gas n/a 66 Star Chief Executive 57k mile 67 IH Scout project 2WD "Indian Scout" 69 Le Mans 2 dr HT 350 85k mile 15 sec 1/4 69 Firebird 400 Burgandy/Black 70 Olds Rallye 350 F85 4 speed 3.91's 70 Olds Cutlass Cruiser Red Wagon 350 101k miles 15 sec 1/4 12 sec w 455 74 Cheyenne Super C10 LWB Gen 6 454 w ZZ502 cam 3.07gear 13.1 1/4, 8.3 1/8 2020 RAM 1500 SLT 4x4 5.7 A8 Hemi 2007 Hummer H3 3.7 liter turd |
#49
Sssooooooooo this has been awhile since it was at the top.
did anyone start making a stock cam for these. Mine has a lobe that is .050 shorter than the rest . |
#50
I haven't heard anything. Just regrinds for good stock cams. I eneded up using a wild solid roller in mine. It's all I could find at the time and I din't think it's any easier now.
Never trust a fart. They sometimes suprise you. http://community.webshots.com/user/motornoggin http://motornoggin.smugmug.com/ |
#51
Keith Collier 61-63 Pontiac Tempest Tech advisor POCI.org |
#52
Tin Tigr, do you still have your isky cam?
#53
Searched for months and called every company from coast to coast, and found that nothing is available. No one has blank cores.
Had to regrind. |
#54
I have a regrind I'll part with...
Parts for sale!!! chief.thundercloud.fc@gmail.com https://www.facebook.com/groups/Dave...acStuffForSale |
#55
This is the one regrind I have for sale.
#56
63 banshee
how much are you asking? specs? |
#57
WOW I didn't realize they had that much lift.
GT. |
#58
Very interesting grind!! The factory performance cam is around .410 lift with Lots more duration, 270-80 ish. Thats cams specs .480 lift @ only a 208 duration?? Did you actually put a dial indicator on it to double check the specs on the box? What would those specs be good for?? A turbo or boosted application??
#59
This is duration at .050", not advertised duration, which is where a factory 270 number comes from.
I'm moving the cam sale to my '63 T4 for sale thread (link below). Didn't intend on hijacking this thread with it...
#60
210 @.050 =260 advertised 220 @.050 =270 advertised 230 @ .050 =280 advertised and so on..... So whats the advertised duration on a stock 4 banger with a 4 barrel carb?
Tighten it until it breaks then back it off 1/2 turn |
Thread Tools | |
Display Modes | |
