#41
Car is 3 speed th400 with 2.10 first -- leaving at 12lb boost - 60ft was only 1.08 - the bigest change we made was 4 link set up and a new pair of real expensive shocks.
Ill add some pics -- if I ever get home. |
#42
Way to go Curt. Number 2 Qualifier in Top Sportsman at Las Vegas. I think there were 51 cars in the class.
#43
Thanks guys - the track got pretty cold or I think there was a 6.50 there - then the trans let go - again.
#44
curt- not that your TH400 isn't big bucks already, but r u considering a different 3 speed trans similar to what langer runs?
#45
Im not sure what Langer runs - but I believe it is a th-350 or th 200 dirivitive -- I think this 400 is supposed to be stronger - but uses up more power - John may correct me here?
#46
i think he runs a torqueflite...
#47
Is it time for a 2 speed Lenco? or a big old Allison?
IIRC Langer runs a Proflite which is an A904/998 derivative weaker stock than a 727. |
#48
Curt,
Who's T400 transmission were you running? |
#49
Rosslier thx 210hd
#50
...I'd like to know what failed: Converter or Input shaft to FWD case...
#51
soon as I get help lifting that SOB out -- we will find out -
#52
I run a proflite. It can barely handle the power I have. Most of the "fast" auto turbo promods run the Rossler 400.
#53
Curious to see what part failed. Rossler builds some pretty stout pieces.
#54
ok - got it on the lift last night and pulled the pan -a lot of fine metal ad what looks like small pieces of bushing and not really any clutch material - at this point Im thinking front pump or convertor??? It did push out the front seal -- thats where the leak came from.
#55
John -- what do you do to make that trans live? any special maintenence ect.?
#56
I keep pushing the limits of the trans with each tq increase. Every time I break something in the trans, we engineer a new part to find the next weakest lint...
#57
![]() Quote:
#58
Curt. Who do you use for converter with this turbo deal? With HP numbers like you are making,it would take a pretty stout piece to handle all that power.
#59
I am using a Neal Chance - it has been great in the past -- we will see this weekend when it comes apart - maybe the old girl cashed it in ??? I was getting ready to pull it out last nite and was kinda surprised to see that the front pump did not look like it got hot -- yet it pushed out the front seal -- hmmmm I hate surprises
#60
Time for a Liberty!
1969 GTO Judge Ram Air III 1968 Catalina "Darkside" Vert! |
Thread Tools | |
Display Modes | |
