#121
If you read further down on the first page, it's the correct casting for a '64 GTO 4bbl. Not an easy engine to find. I know most like the larger cube engines but someone, somewhere is looking for a correct '64 GTO engine I'm sure.
Greg Reid Palmetto, Georgia |
#122
#123
I know the automatic motors start with a Y, but I don't know the specific codes.
Tod Hoffmann 1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd 1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler 1996 Chevy K2500 ECSB 'Poopy' 2002 Honda VTX1800C 2016 Cadillac CTS Premium My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826 |
#124
If you are looking for a 66 389, I would be more conscious of a complete motor with a correct date code as opposed to one with the correct stamping. This is what certain renowned restoration shops usually do. You can guess what happens next.....
#126
Well, one thing in favor of the '66 engine is that even without the correct stamping....anyone with much knowledge can spot a '64 engine at a glance and know it's not for a '66. With the '66, they'd have to work a little harder to know it's not correct.
#127
Re-stamp?
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
#128
Noooooo! No a wise thing to do. Hard to do and not be noticed. And worst of all, it ruins it's value.
#129
Not much going on with the car right now. Its 10 degrees outside and too cold in the garage.
Besides, Im waiting until after Christmas to buy anything. I want to see how much money Santa brings me. |
#130
Yeah, I'm waiting 'til after Christmas to buy anything too...but I'm waiting to see how much he takes from me.
#131
Ya know, I was going to post about the too Greg. But it is just too scary to think about.
#132
Santa's bringing me a new Covercraft Flannel Car Cover for my '72 GTO, the present one is 30 years old and needs to be retired.
Bill Nawrot (Wino Bill) 1972 GTO Hdtp One Owner, GTOAA "Concours Best Original" 2007, 2013, and 2019 Auto-Biography http://oneownercollectorcar.com/inde...to-bill-nawrot HPP Sept. 2014 https://www.hotrod.com/articles/1972...-gee-no-g-t-o/ YouTube MCACN 2014 http://youtu.be/1IPQVPevbxU 1967 GTO Conv |
#133
I'd say you got your money's worth Bill.
#134
Shocks
I'm ordering the Kyb. I've been happy with these in the past so I'm getting them again.
Question.....they have two models that fit a GTO. 5504 and 5507. The only difference is the 5507 is a bit longer typically used on full size cars. I put these on my blue Lemans after I found out the wheels and tires needed more lift and the 5504 wouldn't support it because they were too short. I don't want to buy another set if I buy the 5504 and find myself in the same situation. I. Haven't decide what to get with tires sizes yet if I do make the change and ditch the RI wheels. Question is this.... If I buy the 5507 and don't need the extra length, will the ride be affected at all? |
#135
Have you considered air bags? They have worked well for me in the past. They are relatively inexpensive, adjustable, and don't have a negative effect on ride quality. About $100 at jets.
#136
Yea but can they adjust right height? Ive never used them. Its sounds like they are the same principle as air shocks.
#137
Paul, I have both and like the setup alot. Airbags can change the ride heigth but not like the airshocks can. They more or less can soften or stiffen up the ride. Combination of the two will help your car have much less sway going around sharpe curves like an on or off ramp. Also lets you have more clearance for wider tires.
I can fill the airbags on mine individually, and both airshocks at the same time.
#138
Took the car to a local reputable shop today. Wanted to get the motor compression tested before we do anything to it. It just runs like crap. Didn't get that far though. First four plugs that were pulled, one could not possibly have been firing. Moved over to the driver side and three of the plugs were caked in what appeared to be fresh oil. Don't think three of them were firing either.
Looks like I'm going to search a complete 400 and stick it in the car. At least that's what my first thought is. Budget is tight and I'd just like a healthy motor running int car Plus something I can build on in the future. The 64 389 will go up for sale. It's a good motor, just needs a rebuild. I don't want to put money intro this motor. |
#139
If it's a numbers eng would be worth holding on to sucks you don't live closer we could freshen up yours for what your going to pay for a good running eng..
#140
Its not numbers matching. Its a 64 motor in a 66.
Thread Tools | |
Display Modes | |
