Are their any newer automatics that will bolt up to
the 287 ? I'm would like a smooth shifting trans. that is also capabile of towing. Thanks in advance.
55starchief |
55starchief |
I am not a 100% sure the bolt pattern on the rear of block is same as a later model motor but if it is I am sure there are other options available.A lot will depend on motor mounts too! I had some friends that have put TH400's in 60&61 cars. You might want to post this question in "Pontiac Drive Train-Street" section where more people will read it. There are some very knoledgeable people on this board willing to help. Jusy need to get to them.
Good Luck Outlaw Pontiac Racers Association"For Those Who Live The Legend" Do it now fool! Life is short. 60 Ventura 4300# 12.38 @ 108.10 / 1.66 60'
ECM member. 2008 Outlaw Pontiac Drag Series Champion MANDRA Do it now fool! Life is short. 69 Grand Prix/3163lbs / IAII 535 w/ Tiger heads by Gaydosh....9.35@ 144 so far.. through mufflers. 1.26 60'. Going back to track with pump gas engine.... My 60 Ventura retired to street/strip duty.. |
The bolt pattern goes 55-60.
You can get a Hydramatic to shift pretty decent.They don't always take your neck off. If you set the throttle pressure and adjust the bands,they work good and they are very strong(they were used in Army tanks). The difference between inlaws and outlaws-outlaws are wanted
The later trans may bolt to the block but there are other differences.It's not quite that easy. Besides those trans are not as good as the 1955 trans.
There is a company that is working on a solution for putting newer trans in 55-60 Pontiacs. Wilcap http://wilcap.com/index.html, has a 61-63 trans adaptor on the market now. They have the adaptor plate developed now. What they are working on now is some way to use the stock rear motor mounts. This adaptor will allow both BOP and Chevy trans types, GM AUTO PG, TH350, 400,700R4. Should be out in early 04. Should be the ticket. Jack
Another company I've found is Bendtsen’s http://www.transmissionadapters.com/index.htm
they currently have a kit available, even includes starter. Ed.
55starchief |
Thread Tools | |
Display Modes | |
