Making Anti-roll bar for leafspring '65 GTO - Thoughts?
Got no response in the race section, hope for more here!
I am going to try and make an anti-roll bar for my GTO so it will launch level. I believe a 1" front swaybar from a Dodge PU can be put behind the rear-end and mount to a crossbar welded to the frames 20" behind the housing and the ends will attach to the leafspring/housing bracket. I was planning on using polyurethane bushings. Figured I could do this for under $100 and eliminate the twist on launch and hopefully improve 60ft's or at least make it more consistent. Any thoughts/suggestions? Thanks, PHILLYGOAT
PHILLYGOAT 1965 GTO/ OEM Block, Crank & D-ports(all slightly modified of course)/ 3550lbs/ Full Exhaust/ Foot Braking 1.41 60ft 6.45@104.97mph 10.25@127.12mph(Pontiac Heaven) More Details on GOAT http://www.pontiaczone.com/forum/vbpicgallery.php?do=view&g=379 GTO Burnout http://www.youtube.com/watch?v=nZqdcH0Ltc4 |
Inquiring Minds wanna kno
GOAT,if you do that be sure to share parts used and detailed pics.That seems interesting.Love to see the results.
Gotta Luv some old Muscle.. 64 GTO Sedan Produced w/PwrSteering-PwrBrakes-AC-Padded Dash/Rally clock/ RemoteSideMirror 3sp&3:08/10 boltPosi-Pwr Windows-Pwr Antenna Silvermist w/BlackVinyl Top http://s161.photobucket.com/albums/t201/dracowizard/65/ |
30mm Anti-Rollbar for $128.33(tax incl.)
Total cost is more than I expected(always is!), but I feel good about the install.
$19.50 30mm(1 3/16") swaybar from 86 Dodge PU 29.30 Metal for boxing rear frame & crossmember for swaybar attachment 30.00 Labor for welding 24.53 Energy Suspension Graphite Impregnated Greaseable Polyurethane Mounts 5.00 Cut-off & Grinder wheels 10.00 Grade 8 nuts/bolts/washers 10.00 Gas for running around to get all the parts $128.33 I have probably spent two days running around and modifying parts to fit. It was actually fun to do and I hope it will work as well as I think it will. I now have to pull the engine and see why I lost oil pressure. Testing of new anti-roll bar may have to wait till next year. I will try to get some pics so you can see what I did. PHILLYGOAT
Thread Tools | |
Display Modes | |
