PHS documented RA II GTO, Verdoro Green with Black Cordova roof built 5/31/68 and sold by Seltzer Pontiac in Chicago. Options and codes listed below:
347 400 4BBL RAM AIR II V8 engine 358 4 SPEED MANUAL TRANSMISSION 361 SAFE-T-TRACK DIFFERENTIAL 382 RADIO PUSH BUTTON 414 COVERS-HEADLAMP RETRACTABLE 424 MIRROR-O/S LH REMOTE CONTROL 453 WHEELS-RALLY II 472 CONSOLE 501 POWER STEERING-WONDER TOUCH 502 POWER BRAKES-WONDER TOUCH 521 DISC BRAKES-FRONT 621 SPRINGS & SHOCKS-RIDE & HANDLING The car is currently Midnight Green (1969 GTO color) painted about 10 years ago and is a nice driver quality job done by prior owner. I purchased the car 2-1/2 years ago and removed the WT motor, M20 4spd and 3:23 posi. Currently, the car has a fresh 72 pontiac 400, 30 over with Armasteel crank, stock rods with TRW forged stock style pistons, new rings and bearings with the rotating assembly balanced. RA II 041 cam. Heads are RAII Service replacement with stock valves and springs and were recently cleaned and checked. Intake is stock, quadrajet carb is 7028268(not correct for this car). The engine compartment looks stock and detailed. Transmission is 68 M21, rebuilt with stock internals, shifter is competition plus also rebuilt. Rear end assembly has the original ZL stamp on the axle tube and has a new 4:33 and posi unit. Exhaust system is Pypes 2.5 in system cast iron manifolds, x-pipe, race flow mufflers and correct tail pipe tips. Other upgrades include driveshaft loop, in dash tach, rear springs, shocks and air bags. Car is located in Findlay Ohio. $80k or trade for 1968 RA II FIREBIRD. Email me if you want more information or if you want me to call you. Rwatson@bright.net |
One more picture
More
More pictures
Bump
Price Reduced
$75k |
I assume you are including the original drive train with this purchase?
Thanks!
Member Of The Baltimore Built Brotherhood! |
No the original engine and trans are gone.
Might be a little expensive at 75k w/o original drivetrain?
1974 Lemans Sportecoupe GT (daily driver) .030 over 354, #47 heads (84cc), Lunati voodoo 700 camshaft (207/213 @ .050), logs, 2.5 duals, X-pipe and Dynomax super turbo mufflers, 3.08 rear |
(cough, cough)
"Moon", you might want to look here! (cough, cough) @ OP GLWS!! @ OP incase you're interested, I have seen correct carbs occasionally pop up on eBay - they are actually a good deal easier to find than the '68 RAI (OEM not SR) carbs! (just please do your homework so you don't get burnt!)
Make an offer he can’t refuse,he’s a good guy he won’t get made worse thing that would happen is he will say no.
Or mad
Classified rules violation.
Vacation for one month. If I see anything like this in the classifieds it means an automatic suspension. |
GTO is on eBay for a few more days.
PRICE REDUCTION..... $70K OBO
Car is located in Van Buren Ohio which is only 1 hour and 20 minutes from Summit Motorsports Park. Contact Rwatson@bright.net or call Rick at 567-429-9953 |
Thread Tools | |
Display Modes | |
