Carter M4566 fuel pump problems
Has anyone had issues with this pump? Bought new in March and just stranded me last Friday. It's a 2-line pump that works well early GTO's etc. After pulling the pump, it seems the arm is completely disconnected from the diaphragm. Just flops around, no spring pressure at all. I would do a further autopsy but at least Rock Auto is going to replace it under warranty and want it back so no cutting it open.
65 Tempest, 400, TH400 86 Fiero SE 2.8 |
Yup, same problem I had. Arm broke because I believe they are using the wrong arms on these replacement pumps now. See my thread from about a month ago.
https://forums.maxperformanceinc.com...d.php?t=868529
1968 Firebird 400HO convertible 1971 Trans Am 4-speed, white/blue |
Thanks!!
71' GTO -original 400/4-speed/3.23 posi 13.95 @ 102.1 on street tires @ 4055lbs. ‘63 LeMans- ‘69 400 w/ original transaxle. 2.69 gears. |
Mine is pushing 11 lbs. Not the 6 quoted.
........I'm just learning as I go....... |
Mine was also pushing almost 11 lbs pressure.
I put a regulator on it to keep the Q-jet happy. Sent from my iPad using Tapatalk Pro |
Did you hide your regulator?
No. I plan on doing something different after I get all the other bugs worked out. So I put it in a convenient spot temporarily.
I don't mind running a regulator. It's just ugly and all the extra hoses.
Agreed. As soon as I’m sure all the fuel lines are clean I’ll probably get a RobbMC pump and ditch the regulator and in-line fuel filter.
Sent from my iPhone using Tapatalk |
I’ve got a RobbMc on my 71 which is a new build. And my son’s 79. Which had been working well since 2017. I’ve got a stock pump and an electric pusher on my 68 Firebird. Will probably replace that with a RobbMc as well. I just need the time and a place to swap it. Because, I will also be replacing stock line and pickup with a 1/2”
Thread Tools | |
Display Modes | |
