How or what is the best way to get oil (that has burnt in) off Alumi coated headers?
Looks like crap. |
Looks like crap. |
I've heard of using oven cleaner, but have never tried it.
I found a cleaner called sd20.I dont know about the header stains you have but it will take off shoe polish that has been on lexan for years and does not hurt the lexan.I would try it.Brian
Be carefull of the feet you step on today.They may be attached to the a$$ you kiss tomorrow. |
Alloy wheel cleaner I think it is...
'71 Holden HQ Monaro - 3850lbs race weight, 400c/i - 11.4 @ 120 '66 Pontiac GTO - 389, 4 speed street cruiser |
I have used SOS pads(steel wool) and oven cleaner on my exhaust with good results. If the coating is real new and shiny the steel wool may be on the aggresive side. Try it on the back side first in case it dulls it too much...
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
Yes, Mag Wheel cleaner and also heard that the Castrol Super Clean works too.
Home of WFO Hyperformance Shaker induction. |
Yeah I love that castrol super clean too,use it all the time,just don't get on any painted surfaces if you can,it is pretty strong stuff.That reminds me I need a couple gallons more,thanks Larry!
Im a fan of the Castrol Super Clean too.......I keep a couple gallons of the stuff on hand at all times. I have even used it to clean oil/tranny fluid off my concrete before.
"It is foolish and wrong to mourn the men who died. Rather we should thank God that such men lived."- General George Patton "Perpetual peace is a futile dream."-General George Patton "I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them."-Thomas Jefferson "Any society that would give up a little liberty to gain a little security deserves neither and will loose both."-Benjamin Franklin |
Fix your oil leak...
"Take your time, don't live too fast, troubles will come and they will pass... |
Dude--good old lacquer thinner works great.
fasteddy |
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Rashionality:
Fix your oil leak... <HR></BLOCKQUOTE> You should talk. Norwalk diaper boy. LOL. It was the BOP rear main that started to seap and got worse. But now the engine is out and will be fixed. Just need to get them clean.
--------- "What does a girl know about cars?" ...care to find out? |
elbow grease
70 GTO 462 E-Heads TKO-600 9-Inch/3.60's |
Ok, so would you use the same sort of stuff to get burnt oil off nickle plated headers?
If it's got tit's or wheels,, It's gona give ya problem's |
Just burn it off with a little mor jet in you plate system
77 Trans Am All Steel, on 10" tires 8.30 @ 165 mph 3,380 LBS Mat it! Spray it! Chute it! Just another 8 Second Pass! |
