Recommended paint for H.O./Ram Air Manifolds??
I purchased the 67 High Output style manifolds from our host for my 67 goat, and I'd like to put on some sort of coating on them to keep them protected.
I purchased some Engine Enamel that when you spray it on it looks like brand new cast iron. However the paint is rated up to 500 degrees. Now I know the exhaust portion of the car gets pretty hot, but how hot I'm not sure. Is the stuff I bought going to cut it or am I going to have to buy another exhaust paint with a higher temperature rating?? Don't want to put in the effort of putting it on only to find out once I actually get the car going again that the paint is chipping. |
POR-15 "black velvet" manifold coating
Home of WFO Hyperformance Shaker induction. |
Thanks a BUNCH, went ahead and ordered it right after you put up the recommendation. Any special or good way to put it on?
follow the instructions on the label and you'll be fine.
I used the eastwood exhaust manifold paint w/a foam applicator as the suggest. Looks great and has last quite well over several long distance drives. On my pontiac, I also covered the center two exhaust ports on the head since the pontiac blue always burns off as well.
-Jim Doran- 1965 389 Tripower; 4 speed; convertible 2019 Tesla Model 3 Performance 2016 Chevy SS; Sold 2001 Toyota Tacoma 4x4 2008 Infiniti G35x |
Someone on these boards said they had good luck pre-painting the exhaust ports with Eastwood's Stainless, then painting the whole head with color- Pontiac blue, of course! I'm trying that on my heads, but it will be a while before I run it and can post feedback.
Exhaust Manifold Paint
I've used Nucast high temp by VHT Paints. Looks great and is rated to 1500 degrees.
I was thinking about this and really there is nothing wrong with just leaving them as cast. A car that's used will look used and although trying to maintain a clean look if fine. So is allowing them to "properly age" the way any driven car will. Besides, if they are rusty you can spot a leak faster.
Build it fast, build it right, hold On TIGHT !!! |
wouldnt u want the cast iron por vs POR-15 "black velvet" manifold coating. i would think black velvet is black..isnt it?...as for doing the heads first, i would think u would use por-20 which is silver so if the blue paint does peel, at least u have a fbright lake color underneath
