Old 04-07-2006, 06:40 AM
ModifiedPONPON's Avatar
ModifiedPONPON ModifiedPONPON is offline
Default Anybody here have a big block chevy motor in a 73 formula?
Anybody here have a big block chevy motor in a 73 formula? I need some info please God anybody.
Old 04-07-2006, 07:50 AM
BILL BOWMAN1's Avatar
A WHAT!!!!!!!!!
Old 04-07-2006, 09:59 AM
J.C.you's Avatar
J.C.you J.C.you is offline
i just may know someone that knows someone's buddy that may have one......what u want to know?
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 04-07-2006, 10:09 AM
formula400's Avatar
formula400 formula400 is offline
is this a late april fools joke?
Old 04-07-2006, 10:17 AM
Brian Baker's Avatar
You need to talk to Jim Zeek's brother...he's the one that hasn't fallen and hit his head yet like the rest of us. Or is he the one that hit his melon and the rest of us are ok?
Old 04-07-2006, 02:33 PM
TA454 TA454 is offline
Wow Brian your fall must have caused some dain bramage,
If I didnt know better I would almost mistake that comment as a compliment.
What do you need to know PONPON?
Old 04-07-2006, 03:30 PM
I don't have enough money to go out and buy what I want like some of you. Yeah, I've seen you at the drags with your semi's haulin huge trailers with 2 drag cars painted the same color as the semi. I have to work with what I got. I have a chev big block 402 and a new on the pallet TCI TH400. I would like to know if the th400 is going to bolt up perfectly in the 73 formula. I don't want to get stock camaro mounts, I want aftermarket SOLID mounts like what Moroso makes. They skipped the 73 for some reason. Which motor mounts do I use and will they be a bolt in job also? I have 2 days of garage time and today's the 2nd day. I'm using the shop to just get the motor in, I'll do the rest in my gravel driveway. I appreciate anyone who has the knowledge to help. Thank you in advance.
Old 04-07-2006, 03:50 PM
You want to use moroso solid motor mounts for a 72 camaro (the last year big block was available). As far as the trans your trans cross member will work as long as it is for a th400. As that cross member is different from the th350/4speed. Solid motor mounts are a good choice but i would suggest against the solid trans mount. go with a poly trans mount you need to allow a little movement or you will crack your trans case. If you do not have the crossmember for a th400 you can move your 350 crossmember back and bolt it to your 400. Once it is bolted to the trans you can square it up to the subframe and drill new holes. That is what i did with mine i laid everything out and drilled a .406 hole thru both rails of the frame on each side. I then opened the hole on the bottom to allow the head of the bolt thru just like the original mount location. Hope that helps
Chuck Zeek
Old 04-07-2006, 06:29 PM
OK, Now were talking valuable information here. It was suggested to me by Jeg's that I use solid motor mounts and transmission mounts since I'm pushing 500 hp to start with. They said that if I use rubber mounts, it will let the motor and tranny shift around and cause cracks in the tranny or other parts? What do you think?
Old 04-07-2006, 06:36 PM
OK, Now I called Jeg's back and they said the same thing again about solid mounts all the way around. I told them I'm gettin a different story from the Pontiac Forums. He put me on hold and talked to his senior advisor and got back on the phone and changed his story to exactly what you're saying. I appreciate this info from people who actually have done it. I may have more questions in the future, Well, I guarantee I'll have more questions. Thank you again.
Old 04-07-2006, 06:44 PM
Lloyd-TX's Avatar
Lloyd-TX Lloyd-TX is offline
Moderators, this thread should be moved to the "non-Pontiac motors in Pontiacs" heading!
http://216.178.81.108/forums/forumdisplay.php?f=423
Regards,
"455HO" Lloyd
Old 04-07-2006, 06:53 PM
"Puddles the Pontiac" "Puddles the Pontiac" is offline
Send a message via Yahoo to "Puddles the Pontiac"
hey while we're at it, whaddaya think about a CJ Ford in my '65 LeMans?
Old 04-07-2006, 08:37 PM
notenoughmoney notenoughmoney is offline
why not, looks like your already doin a good job with abortions
Old 04-07-2006, 09:18 PM
guess that one went over my head.
i was only joking bout the cobra jet thing, but it is still a 428 right?
Old 04-07-2006, 09:37 PM
i got a rotary engine lets try that out
Old 04-07-2006, 09:42 PM
briggs and stratton? my car uses their key blanks doesnt it?
Old 04-07-2006, 09:55 PM
no, a pull cord located under the dash
Old 04-07-2006, 09:59 PM
and here i thought i was just pulling the choke...
Old 04-07-2006, 10:38 PM
lol
Old 04-08-2006, 05:15 AM
If you wanna buy me a 500 horse Pontiac engine with a tranny to back it up, I'll gladly go with a Pontiac drivetrain. Come on, put your money where your mouth is? No excuses, come on.....pay for it.
