Old 03-09-2007, 07:54 PM
Dave _68_gto's Avatar
Dave _68_gto Dave _68_gto is offline
Default Firebird is almost complete
I took a few pictures today of my Firebird project.
ID:	84997   Click image for larger version
ID:	84999   Click image for larger version
ID:	85000   Click image for larger version
ID:	85001   Click image for larger version
Old 03-09-2007, 09:52 PM
Robert Williams's Avatar
Robert Williams Robert Williams is offline
Very nice Dave, looks like you put a lot of work into that beauty. Post some pictures when it's compleated.
"Three may keep a secret, if two are dead"
~ Benjamin Franklin ~
Old 03-09-2007, 10:38 PM
Ron H's Avatar
Ron H Ron H is offline
Looks great. I am a week away from paint on my car. What are you expecting to run in that beast?
68 Firebird
Are you running with the wind or breaking it?
Old 03-10-2007, 11:22 PM
quick67bird's Avatar
quick67bird quick67bird is offline
Looks nice. Are those tires 295/65/15 or 315/60/15? I have mini tubbed my bird and I used to use the 295s, but want to see if the 315s will fit.
Robert
67 Firebird 467 cubic inches 7.71 @ 92 in the 1/8 and 11.69 @ 115 in the 1/4.
Old 03-11-2007, 12:06 AM
10second70GP's Avatar
10second70GP 10second70GP is offline
THOSE LOOK LIKE THE 315/60/15 THIS IS VERY SIMILAR TO HOW MY NEW CAR WILL LOOK LIKE WHAT SIZE RIM YOU RUNNING 15X10 OR 15X12
Old 03-11-2007, 12:28 AM
I was going to run 15 x 10.5 wheels as I need 7.5" backspacing so that the tires fit under the car.
Robert
Old 03-11-2007, 09:10 AM
Ron H's Avatar
7.5" back space , wow. The 315 x 60's are how wide? 13.5 max? Wow my 2000 post
68 Firebird
Old 03-11-2007, 10:49 AM
Thanks everyone.
Ron H, I have a problem too much car too little motor. I really over did the project from my original plans. But once we started I couldn't stop. This motor I hope will run low 12's, I plan on a motor swap in the fall.
The tires are 325-50-15 from Mickey Thompson 3757R. They measure 14 inches wide. The wheels are 15x10.
My friend took some better picture I attached a few. Dave
ID:	85105   Click image for larger version
Name:	Firebird 3-7 1.jpg
ID:	85106   Click image for larger version
Name:	Firebird 3-7 2.jpg
ID:	85107   Click image for larger version
Name:	Firebird 3-7 4.jpg
ID:	85108   Click image for larger version
Name:	Firebird 3-7 5.jpg
Old 03-11-2007, 11:06 AM
Ron H's Avatar
Most people have too much engine and not enough car so you are not in a bad situation by any means. Good to see you added the bar being a convertible. Most people are not as safe with them.
What engine is in it now?
68 Firebird
Old 03-11-2007, 12:02 PM
Yeah centerline makes them in a 10.5 wide wheel and then weld makes them with a 10 wide wheel. By having this backspacing with the second gen rearend that I got a killer deal on that is as built as you can get a 12 bolt I will be able to tuck the tires inside of the rear quarters instead of being even with the outside.
Robert
Old 03-11-2007, 12:05 PM
After seeing how those 325s look on yours Dave I may have to rethink the 315s which are 29.6" tall and look into the 325s as they are only 28" tall and I wont have to worry about the tires coming into possible contact with the quarters.
Robert
Old 03-11-2007, 12:08 PM
In post #8 pic 3 it looks like you have competition engineering ladder bars. Is this correct? If they are could you possibly get me some more pictures of how you mounted them as I am in the process of doing mine now? I also like how your shocks attach to the backside of the plate.
Robert
Old 03-11-2007, 12:44 PM
Ron H's Avatar
I am running 30 x 10.5 x 15" Radial slick without issue and no mods to the quarters or wells. These slicks don't grow much if at all.
68 Firebird
Old 03-11-2007, 12:58 PM
Ron, the motor is a 406 I purchased from Alex Brooks (WARPED) brother. They had it in a 4 door Ventura.
Robert, It is a competition engineering ladder bar set up. I'll take more pictures of the rear and post them tomorrow
. I'll post a few more pics. Dave
Name:	Firebird 3-7 6.jpg
ID:	85118   Click image for larger version
ID:	85119   Click image for larger version
ID:	85120   Click image for larger version
Old 03-11-2007, 01:16 PM
Jack Ferris's Avatar
Jack Ferris Jack Ferris is offline
Nice Job on the cage. Nice welding.
Jack Ferris
RestoRacing LLC
www.restoracing.com
Sandy, UT
