I went to milan dragway Friday night with my new KRE heads. My best last year was 12.57 at 106 with a 1.72 sixty ft. The only things changed were the heads, port match the intake, and set the timing back to 30deg. The end result was a 12.26 at 110 with a 1.66 sixty ft. We didn't have any time to make any changes because the track was packed, only got two time trials before eliminations. I talked to a friend whose similar GP runs 11.0's and he gave me three ideas to try if jetting and timing changes don't help. #1 performer intake too restrictive,[ try an RPM or Torker],.#2 switch from spreadbore Holley to squarebore[ better fuel distribution]. #3 is my Ultradyne 288/296 H10 cam not the best to use with these heads,[try a single pattern cam]..Maybe I'm let down because that 12.57 was run with a blown front power valve and a burned #8 exhaust valve on a set of 6x-8 heads. I hope there is a cheap fix here, budget is getting tight! THANK YOU.
![]() ![]() Quote:
http://www.youtube.com/watch?v=iJrDl3nRNCM http://www.youtube.com/watch?v=Fvywdocl4GA http://ultimategto.com/icongraf/65headtitle.jpg |
What engine? Combo?
How did the weather match between last year and this year? Timing at only 30 degrees you must be running a 455+, otherwise you would need more. A 1.66 60' and 4 mph gain is pretty good without tuning for the better airflow! Give up some details so we can try and help. JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! ![]() |
I too have a Grand Prix mine is a 82 with a 455 with the same cam Ultra Dyne 288/296 Hydraulic cam with 1.52 rockers my heads are #64's ported by myself 221cfm intake and 200cfm exhaust. I run the Performer RPM intake with a Barry Grant 850 Speed Demon. I had mine at the track it ran 13.11 at 101 mph with a 60ft time of 1.77. My first run was a 13.51 (i had trouble getting out of second gear. Driver error). When I left the line I left off the brake both times. My goal is to run in the 11's. I didn't lower the tire pressure; i'm running MT 28x12.5x15 and the timing was set at 12 degrees initial. I have a 9" Ford rear with a 3.70 gear and 3200-3400 PTC stall converter. I'm running the Ram Air shorty headers that have been opened up to 2.5" on the collecter with 2.5" full exhaust. my rear suspension is Hotchkis boxed upper and lower control arms and a anit-roll bar, Eibach springs with C/E 3 way adjustable shocks. I need help also. i'm looking at changing my heads to KRE's or Edelbrock, but I would like to get the car close as I can to the 11's before I make the switch or can I run 11's with cast iron heads. i also drive it on the street.
Fast 82 G & G Perfromance Parts (937)307-6586 |
![]() Quote:
Shopping for a project... |
If I were looking for issues with the UD cams,first thing that comes to mind is degreeing,absolutely all UD cams need to be degreed,they are the biggest offenders of being "off" of all the cams I've done,at least two were off by 9 degrees,both were the hydraulics,and have heard of plenty of others,good cams,but they gotta be degreed IMO.
As for the first combo (81 GP),yeah,loose the performer,and the spreadbore holley,if you want a spreadbore,use a Q-jet with the RPM. Single pattern cam is likely gonna do nothing to help if the cams specs are roughly the same. The mild KRE-D heads did'nt really "add" that much,so I would'nt have expected big changes with just that change. Fast 82,was your UD cam degreed? |
Well lets use some logic here!, you put on better flowing heads, and then went racing, so if the weather that day was about the same as you best run with the other heads, how can you expect to go all the much better with out jetting up for the better flowing heads.Assuming your carb jetting was in the ball park before, I would have jetted up 2 jet numbers off the bat, just to be on the safe side of not melting something!
For your cams power range the RPM performer is the better choise.
SJM |
You picked up about .3 and 4 mph thats about 30 hp,I think thats pretty good for no other changes.Now you just need to optimize the better flowing heads.
Mark 1970 Lemans Convertible,462,6x-4, 234/242 cam.3.42 posi.12.55@109,4100 lbs...SOLD.... 1968 Firebird , 467 , KRE d-ports ,stock type suspension,3100lbs (1.30 60')(6.08 1/8)(113.43)different runs 9.59 @140.71 on E85 all motor 8.97@148.63 on 150 shot |
You probably need an RPM or better intake to utilize the flow on the heads. If they are ported an rpm will even choke them unless very well ported.
Need more info on combo as noted above, exhaust, converter, gears, tires.
68 Firebird Are you running with the wind or breaking it? |
Did you check for proper pushrod length? When I went from my home ported 6x's to unported KRE's I had to use a longer pushrod.
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too |
I had to go to a longer push rod as well.
![]() Quote:
![]() Quote:
![]() Quote:
1 -6 an line with a dual feed or 2 -6 lines from the regulator?
What is your total timing? What are your shift points and trap rpms?
Which spreadbore are you using? A 650 or an 800? Single or dual line? I've gone 12.22@ 110 with a dual line 800 spreadbore double pumper. I think I would do the intake upgrade first and go from there. It's definitely the glaring mismatch in your combo.
![]() Quote:
I am using a single -6 line going to a dual feed. My shift point is 5200 rpm. When I dynoed the engine my combo made power up to 5250 rpm and the total timing was 40 degrees. I know 40 seems high but the engine took it. Every pass I made I adjusted timing and the engine picked up more hp and tg my final numbers with a Q-jet and a cast iron manifold with the shorty ram air headers was 421hp and 532 ft lbs of tq and that was at 40 degrees total timing.
![]() Quote:
You should have 2 separate lines from the regulator.
![]() Quote:
![]() Quote:
